Old 31st December 2005, 01:33 PM   #1
Send a message via AIM to 69stingray Send a message via MSN to 69stingray Send a message via Yahoo to 69stingray
Default HELP with Box Modeling Software
Hello Everyone.
I have a couple questions/requests for someone with a nice box modeling program. I have some inspiration from Darren Kuzma’s Cynosure . Can someone model an enclosure with 6 drivers in it? Two (2) 8” Dayton DC200, two (2) 6.5” Dayton DC160S and two (2) 5.25” Dayton DC130GS? The proposed enclosure is 5.76 ft3 (160.10 L) with two (2) 4” ports at 10” long.
I would be curious to see a plot of the driver SPL, the port SPL and the combined response. Not sure if this is possible.
Is there a way to take thse 6 driver and develop parameter to simulator (1) one equivalent driver (for use in WinISD)? I think I read how to do that in magazine at one time. Some parameters are additive and some parameters you take the average, or something like that.
Thanks for your help!
BTW, I am thinking of using the Dayton 1-1/8” silk tweeter. The baffle configuration would be:
5.25”
Tweeter
5.25”
6.5”
6.5”
8”
8”
Here are the parameters:
8” (DC200):
Vas: 57.76 L
Xmax = 4.5 mm
Qts: 0.38
Fs = 29 Hz
6.5” (DC160S):
Vas: 22.08 L
Xmax = 3.15 mm
Qts: 0.32
Fs = 22 Hz
5.25” (DC130GS):
Vas: 14.15 L
Xmax = 2.5 mm
Qts: 0.4
Fs = 48 Hz
Audio DIY Page
FOLLOWMY529.COM - Subscribe and follow the performance of my daughter's 529 College Saving Account.
Old 31st December 2005, 01:52 PM   #2
rinox is offline rinox  Italy
Really hard to work on the project you want.... simulate interaction between louspeakers, cross over, phases... for me is quite a huge nightmare
Old 31st December 2005, 02:05 PM   #3
Ron E is offline Ron E  United States
Ron E's Avatar
Not to say it can't be done, but it probably shouldn't be done.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan
Old 1st January 2006, 03:34 PM   #4
I was afraid of that. I thought maybe someone had some fancy software that could do it. To come up with the volume, I used the optimum volume for each driver and added them together....thanks for the help.
Audio DIY Page
Old 1st January 2006, 03:38 PM   #5
Thanks RINOX. For the purpose of this post, I was just curious to get a graph similar to what you get in WinISD.
Audio DIY Page
Old 1st January 2006, 04:40 PM   #6
Ron E's Avatar
I think you didn't understand the answer, because that is what he was talking about. Each driver (if in its own box) would have its own frequency/phase/directivity. The response would then be the vector sum of responses. You want them all to share the same box - then they would interact and the response would change. The reason there is not software to model this is that it should not be done. Drivers with different sizes, parameters and frequency ranges should not share the same volume.
Acoustic Modeling Software HK26147 Multi-Way 0 24th November 2008 11:53 AM
I need 3D CAD Cabinet ONLY Modeling Software sdep777 Multi-Way 5 18th November 2008 09:08 PM
Crossover modeling software idea BAM Multi-Way 0 6th September 2004 09:59 PM
Need help with Modeling Software Wright Multi-Way 26 17th November 2003 01:23 PM
Speaker modeling software ogp Multi-Way 5 26th September 2001 07:36 PM
Page generated in 0.09379 seconds (73.96% PHP - 26.04% MySQL) with 10 queries
