Old 29th December 2005, 12:45 PM   #1
lufbramatt's Avatar
Default first go at 3 way crossover- comments please :)
hi
after a lot of fiddling around on speaker workshop, ive come up with this theoretical crossover for my current project, using scanspeak 8555-01 woofers (virtually given away to me, wouldnt have paid full price for them!), seas mca15rcy midranges and seas 27tbfcg tweeters.
I used the frd consortium tools to simulate the effects of the cabinet and the baffle on the response of the drivers, which gave me a good idea of how things are affected once the drivers are mounted in a cabinet.
Although i have had a go with the speaker workshop measuring facilities to generate frequency responce data for the drivers, im still not sure how much i trust my results, i ive used figures off the web.
Heres the frequency responce and impedance charts for the crossover, if the drivers are connected with opposite polarity i get nice big nulls at the crossover points.
Any comments would be most welcome, especially about the peak in the bass driver at about 3.5khz and what i should do about it.
Ive listened to the bass drivers in various size enclosures and the bass certainly doesnt sound as rolled off as it looks in the charts, so I think itll be ok once its in a room.
Old 29th December 2005, 12:48 PM   #2
lufbramatt's Avatar
and the network:
Old 29th December 2005, 01:10 PM   #3
Paul W is offline Paul W  United States
Paul W's Avatar
Bass appears to be the largest question, but if it's good in-room, so be it. If not, I think you'll need to give up some sensitivity and rebalance level for the other two drivers. The 3.5k woofer peak is probably cone breakup. Try a series RLC trap directly across the driver terminals to notch the resonance.
The mid is showing a little interference with the tweeter...you might try rolling off the top end of the mid with a little steeper slope. (I'm working on my second project with the same MCA15 mid and the 27TDFC tweeter.)
Paul
Old 29th December 2005, 02:26 PM   #4
tinitus is offline tinitus  Europe
try 47uf in midrange instead of 33uf and adjust it with a resistor in
series with the 47uf
make the 1mH in midrange smaller and make the paralel 3uf bigger(with a resistor in series)
and make the crossover so that you can make changes easy
tweeter may be too loud
Old 29th December 2005, 02:26 PM   #5
mistake sorry, NO resistor in series with 47uf(33uf)
Old 29th December 2005, 04:34 PM   #6
lufbramatt's Avatar
thanks, some good ideas. ive never really designed a crossover from scratch beofre so good to get some pointers from more experienced minds.
Ill try them out later on
Old 29th December 2005, 11:43 PM   #7
opp is offline opp  Denmark
opp's Avatar
It seems to me that the midrange is working in a fairly narrow band (roughly 2 octaves). I have read somewhere that the xo frequencies in a 3 way system should be as far a part as possible to reduce interaction between the to xo circuits. Personally I would prefer most of the important midrange to be handled by one driver.
time flies like an arrow ... and fruit flies like a banana
Old 30th December 2005, 01:07 PM   #8
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
You are better off sticking with crossover points on a 3-way that have a ratio of (xo frequency high) / (xo frequency low) = 10. This will give a good 3.4 octaves for the mid.
Example of this is the woofer to 300Hz, mid 300Hz - 3000Hz, tweeter from 3000Hz.
Good luck with the 3-way and have fun with it.
No longer DIY active
Crossover for vifa 2 way setup - how can I find out what this crossover is doing? Tino Multi-Way 11 17th May 2009 04:21 AM
Crossover Layout Comments luvdunhill Multi-Way 13 4th February 2009 02:50 PM
comments on this crossover design...... big_chris Multi-Way 1 29th July 2004 06:36 PM
Can you hear the crossover point of a speaker with a well-designed crossover? 454Casull Multi-Way 11 2nd April 2004 05:48 AM
Comments on Variable Slope Crossover? Rarkov Solid State 7 25th September 2002 10:54 PM
Page generated in 0.10432 seconds (75.69% PHP - 24.31% MySQL) with 11 queries
