Old 29th December 2005, 05:09 AM   #1
Default DEQ2496 for phantom power?
I have a Behringer DEQ2496 and a Behringer ECM8000 mic. I would like to do speaker measurements on my computer and don't want to purchase a phantom power supply for the ECM8000. Is there any way to use the DEQ2496 as a phantom power supply for the mic, and pass the signal through to my computer?
Thanks!
Old 29th December 2005, 06:16 AM   #2
IIRC the DEQ has phantom power built in.
Noah
Old 29th December 2005, 06:52 AM   #3
AR2 is offline AR2  United States
Master Burner
AR2's Avatar
Yes DEQ2496 has phantom power but I do not think that you could make measurement. In another word mic will work only with pink noise provided from DEQ and the signal at the output will be generated pink noise. Much better choice would be to buy small Behringer mixer such as
Eurorack UB 502 or 802. It will cost you $ between 30.00 to $ 50.00 brand new!!!
http://www.behringer.com/UB802/index.cfm?lang=ENG
That will do everything you need and more.
Old 29th December 2005, 07:25 AM   #4
Send a message via AIM to poorstudent Send a message via MSN to poorstudent Send a message via Yahoo to poorstudent
On page 16 of your manual (or the PDF on their site) it tells you how to hook up the mike. The phantom power for the mic is built-in. Let me know how it works. I want one to! I'm jealous!
Old 3rd January 2006, 06:30 AM   #5
His question is if you can use the DEQ purely for phantom power to pass measurements to his computer, he knows the DEQ provides phantom power.
I mean I have no idea, but I wouldn't think so, but then I'm usually wrong.
I picked up a phantom power supply for 30 bucks at Guitar Center.
Old 3rd January 2006, 09:51 AM   #6
pinkmouse's Avatar
IIRC, the DEQ can't pass the unmodified signal to any outputs, it's purely for internal calibration. However, the last one I played with was about 6 years old, so things may have changed since then, but I doubt it.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 3rd January 2006, 06:09 PM   #7
mazeroth,
You can probably get by with one of these:
http://www.sweetwater.com/store/detail/MicroMix/
I suggest this unit to my users who have built-in audio on their PowerBooks, iMacs, and PowerMacs for hooking up a proper measurement microphone.
Hope this helps,
Chris
http://www.SuperMegaUltraGroovy.com
Finally! Acoustic Measurement software for Mac OS X -- http://www.fuzzmeasure.com
Old 3rd January 2006, 07:15 PM   #8
ShinOBIWAN's Avatar
Careful!
The UB502 doesn't have phantom power.
Old 3rd January 2006, 11:07 PM   #9
TNT is offline TNT  Sweden
TNT's Avatar
The DEQ cant be used for measurements. I have one!
Old 5th January 2006, 04:28 AM   #10
Master Burner
AR2's Avatar
Originally posted by ShinOBIWAN
Careful!
You are right, my mistake. As I am owner of UB802 I assumed.
Diy Mic preamp with 48v phantom power cheeseburgerjoe Parts 12 16th September 2010 11:33 PM
Phantom Power might be Bad? mistermisfit Solid State 12 10th February 2010 08:22 PM
phantom power for condenser mic patknk939 Everything Else 5 21st September 2008 07:07 PM
reducing phantom power Sillyboy Everything Else 3 5th June 2006 03:31 PM
Using the phantom power Gabevee Instruments and Amps 2 29th July 2005 05:32 AM
Page generated in 0.11953 seconds (87.86% PHP - 12.14% MySQL) with 10 queries
