Hi!
I'm interested in a ultimate midrange that has lowest distortion and good frequency response extending well into tweeter territory... around the 6k mark. Any help? |
#2 |
A very subjective question with lots of different answers. The main one being "there is no ultimate midrange".
Three different manufacturers that are generally accepted as being quite good: https://secure.wilmslow-audio.co.uk/...e_Units_7.html SM75.150 dome Midrange or SM75.150S dome Midrange http://www.zalytron.com/ C44-8 Ceramic 2" Midrange or C79-6 Ceramic 3" Midrange http://www.phlaudio.com/main.html 1040 6.5" midrange or 1500 6.5" midrange Or you could look at the midrange/midbass section of the LDSG for some ideas: http://ldsg.snippets.org/sect-7-mids.php3
Jont. "It is impossible to build a fool proof system; because fools are so ingenious." |
#3 |
Check out Zaph's summary of 3" inch drivers.
http://www.zaphaudio.com/minitest/ His current favorite is Hi-Vi B3S
Audio DIY Page FOLLOWMY529.COM - Subscribe and follow the performance of my daughter's 529 College Saving Account. |
#4 |
Thank's,
ATC is looking good! But what about Scan-Speak drivers? |
#5 |
JBL 2435HPL, on an appropriate horn, would be a nice start. 3" Be dome, 3" coil, neo magnet, extension to >16k, no breakup to ~14k, response down to maybe 500hz or so on the correct horn with the correct rear chamber, and sensitivity up in the >108dB/watt/1m range, depending on the directivity of the horn. $1400 MSRP (~$250-$300 used on ebay). To get better than this, you'd need to look at the ALE drivers or something else with permendur in the magnetic circuit, and I'm not really sure the ALE would be much better - maybe just different trade offs.
#6 |
The 12M/4631G is probably quite good, but I don't know much about SS bids, only the woofers and the tweeters.
| L-pad attenuator for midrange driver 6 1/4 inch driver | rhythmdiy | Multi-Way | 0 | 4th November 2007 03:32 PM |
| Base driver to suit ESS Heil driver | gerado | Planars & Exotics | 6 | 1st August 2007 07:56 PM |
| FS: Silver Iris Coaxial 15" driver pair (sans XO and compression driver) | theAnonymous1 | Swap Meet | 0 | 24th April 2007 12:09 AM |
| Driver/ driver configuration improve soundstage width | andy2 | Multi-Way | 6 | 16th June 2005 08:47 PM |
| mtm versus tm driver recommendations on project with $500 driver and xo part limit | gsattler | Multi-Way | 4 | 20th May 2002 05:54 PM |
| Page generated in 0.08662 seconds (75.17% PHP - 24.83% MySQL) with 10 queries |
