As per the specs of Drivers the nominal impedance is 8 Ohms(when checked with an ohm meter), so what is Re ? and its importance in the given Thiele Param.
Regards |
#2 |
diyAudio Moderator Emeritus
Nominal Impedence of a diver is not usually calculated with a meter. This is the approx. average impedence of the driver over its passband. Re is the DC resistance, measured with a meter with the driver at rest.
Google is your friend for basic T/S stuff
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.) |
#3 |
Sorry i still did not get,
Re is the resistance of voice coil checked with a Ohm Meter (i.e. say 6.5Ohms), and the specs. of Driver says 8Ohms. |
#4 |
Vikash is right. Re is simply the DC resistance.
Impedance is more complicated. Impedance by definition varies with frequency. The impendance rating is a nominal impedance rating and is the parameter to look for when you are matching a speaker to an amplifier. Travis |
#5 |
The DC resistance is just the resistance of the wire in the voice coil.
When a speaker actually plays, the impedance goes up. Usually around 25% or so. So an 8 ohm speaker usually has a DC resistance between 5 and 6 ohms.
"A friend will help you move. A really good friend will help you move a body." -Anonymous |
#6 |
Here is a chart of both the frequency response, (colored oines) and the impedance, (black line).
This is a Peerless HDS 205 8 inch woofer. The Re is 5.8 ohms. But you can see that throughout the frequency range, the impedance varies. However, at most frequencies it is pretty near 8 ohms. The impedance has a large peak at Fs, the way all conventional speakers do. And the impedance gradually rises as the frequency rises, as all conventional speakers do as well.
#7 |
Thank you all,
kelticwizard Travis Gibby Vikash |
| Page generated in 0.07915 seconds (73.77% PHP - 26.23% MySQL) with 10 queries |
