Hi Masters,
I want to construct a 2-Way Passive 24dB/octave Linkwitz-Riley Crossover with crossover frequency point at 2KHZ... Could anyone provide Links, equations for calculating the Values of Inductors and Capacitors...along with design Tips.... regards, K a n w a r
It's a fruitless endeavor to try and educate a fool that rejoices in ignorance
#2 |
Have a look at these sites.
http://www.bcae1.com/ See sect 91. for a calculator. http://www.passivecrossovers.com/ Have a read here as it supplies plenty of detail. The main thing is not to use the nominal impedance but the actual impedance of the driver at the xo frequency.
No longer DIY active |
#3 |
Speakerholic
#4 | |
OT (but on topic, at the same time) - if im using a vifa driver, i should look at the impedance graph supplied by them at the crossover frequency for my crossover impedance point? Its around 14ohms on the spec's, from the passive XO calc i used it said to measure the driver using a multimeter, i stupidly thought that it just meant the standard impedance w/o load (ie, not connected to anything), which was 5.8ohms... so it should be closer to 14? oh dear, that'll explain a fair bit about how my speakers sound, lol. |
#5 |
ThanX very Much to everyone for providing me the valuable informative links...
ThanX once again... K a n w a r
#6 | |
Ideally it needs to be measured but that requires some equipment and the next best choice is to use the manufacturer's data sheets. That will get you reasonably close and heaps better than the nominal or Re. For a 2nd order LR low pass, A nominal calculation will be about 40% out A Re calculation will be about 60% out So what you have is too low on the inductor and too high on the cap.
#7 |
Hi rabbitz
Then what you suggest....better.... K a n w a r
#8 |
What I'm saying is use the actual impedance at the crossover frequency and throw the nominal and Re in the bin (OK keep the Re for any Zobels calcs).
If you use the nominal, the crossover is going to be out of whack and will not be an effective filter. Measured impedance is best, but data sheet's impedance plot is good and will be miles closer than the nominal as you can see from my previous post. Cheers
#9 |
Hi Rabbitz - ive sent you an email asking a few very quick questions to avoid hijacking Workhorses' thread too much. I will continue to watch this thread, though
Cheers |
#10 |
Thanks... rabbitz
K a n w a r
| Passive potentiometer design help | ehous | Parts | 2 | 17th July 2009 02:13 PM |
| Passive 2.5-way crossover design... | chops | Multi-Way | 7 | 14th May 2007 05:07 PM |
| passive attenuator design | lbenoit | Solid State | 3 | 1st March 2004 10:51 AM |
| Passive crossover design | Pbassred | Multi-Way | 0 | 17th November 2003 08:06 PM |
| What happend to HH Passive Pre design? | Tazzy | Everything Else | 4 | 22nd April 2003 07:21 PM |
| Page generated in 0.10977 seconds (78.29% PHP - 21.71% MySQL) with 10 queries |
