Old 24th December 2005, 08:08 AM   #1
Send a message via AIM to ibanezcollector
Default port direction in a home application
Ok I had some stuff laying around so im going to build a set of home speakers.
Each tower will house:
(2) Dayton DA175-8 Aluminum 7" Midwoofers
(1) Dayton DC28F-8 Silk Dome Tweeters
One 3" Aeroport tuned to 29hz
Xover will be a basic two way(12db slope) at 2k
Enclosure size will be 2.4 cu after displacement and port.
Now, on with the question at hand.
I would prefer to have the port on the rear of the enclosure. Is there a disadvantage of having it in that location? versus having it on the front baffle?
I just dont like the look of a port on the front of the enclosure.
Thanks in advance, and Im Brett by the way, some may know me from Elite Car Audio
Old 24th December 2005, 11:46 AM   #2
Hi Inanez,
Mid-frequencies leaving the port are out of phase vs those from the driver, creating a muddled midrange. Rearported enclosures are able to reduce this effect because the port is out of listening axis; Differences in time delay in the bass range between port and driver have no consequence because of the lenght of the waves. Dave Ellis experiment:
http://www.ellisaudio.com/porthole.htm
Even in 3-way designs, see what is leaving the porthole:
http://www.humblehomemadehifi.com/Soup.html
crazyhub
Driver/port direction a factor? asiquis Subwoofers 2 8th May 2008 06:44 PM
Car speakers for Home In Wall Application geeloe Multi-Way 2 23rd February 2007 05:24 PM
Design Direction for new Home theater setup JerMu Multi-Way 12 9th February 2007 04:19 AM
Powered monitors for home DJ application Flames Multi-Way 9 14th February 2005 06:50 PM
ML-TQWT port direction : down/forward? Jim McPherson Multi-Way 4 2nd June 2004 09:14 PM
Page generated in 0.07939 seconds (66.64% PHP - 33.36% MySQL) with 10 queries
