My first horn experiments
Old 23rd October 2002, 09:11 PM   #1
till is offline till
Banned
Default My first horn experiments
I want to show you the first prototype of my experiments i did in the last 3 weeks.
A while ago there was diskussion about brands of speakers, and at the same time i was very involved in thinking about speakers for my Zen amps.
Nelson said i canŽt go wrong with TAD, so my first idea was to buy TSM-300 ready made speakers.
A lot of email exchange with Cyclotronguy brought me on another way, i hope it will be the right one. Thank you cyclotronguy for your patience and your answers.
Firsts step on this way to build my Zen - suitable speaker is to build a horn for the TAD driver i want to use. here is my first prototype.
I have to say thank you to Timo, http://www-user.uni-bremen.de/~carnivor/ in Bremen too, he answered all the questions i was too shy to ask Cyclotronguy and he made the pics and measurements.
Old 23rd October 2002, 09:14 PM   #2
Banned
first pic
Old 23rd October 2002, 09:16 PM   #3
Banned
second
Old 23rd October 2002, 09:17 PM   #4
Banned
No 3
Old 23rd October 2002, 09:21 PM   #5
Banned
and 4
Old 23rd October 2002, 10:59 PM   #6
roddyama is offline roddyama  United States
diyAudio Moderator Emeritus
roddyama's Avatar
Hi Till,
Super job! What is the frequency band you plan to cover with this horn? What will you do for the low end / hi end? What driver is that in the picture?
Rodd Yamashita
Old 23rd October 2002, 11:09 PM   #7
Banned
The driver is a beyma mounted for test and measurements made by timo. I will use a TD2001, but it will last a little more time to obtain it because of $$$.
This horn is a prototype, we donŽt want to use it for much more than improve design. Next one will have the throat piece, first 50mm after the driver, made of metal for better mounting and precision. The other part will be similar made of maple like this one.
It should be used from as low as possible with the TD - test will show, up to max at maybe 18 or 20kHz - we will see. It should be used in a two way system with one low frequency driver under the TD horn when everything is ready.
This one measures about 330 mm in lenght and inner diameter from 25 to 300 mm. The max diameter outside is about 320mm or so.
Old 23rd October 2002, 11:26 PM   #8
Brett is offline Brett
Brett's Avatar
Very nice work!
What type of flare are you using? It looks long to be a tractrix.
Is the Beyma a 380?
Cheers
Old 23rd October 2002, 11:28 PM   #9
roddyama's Avatar
Till,
You will probably have to cross the TD2001 at 800Hz or higher. If you have a steep xover (>12db/octave) you might get down to 600 or 700Hz with a low powered tube amp and the right horn design.
I'll be very interested in what you do for the mid-bass. Please keep us informed.
Thanks,
Rodd Yamashita
Old 23rd October 2002, 11:33 PM   #10
Banned
Brett: Yes and yes
roddyama: thank you, iŽll keep this in mind. Sure iŽll post more information about this projekt, but it will take some time. (because it is a $$$ projekt...)
My first horn experimentsHide this!Advertise here!
Initial Experiments for Fun stuphi Multi-Way 17 4th June 2009 05:19 PM
Weird cat experiments poobah The Lounge 10 26th July 2006 11:53 PM
SHARC EZ-KIT Lite experiments jwb Digital Source 11 30th November 2004 05:43 PM
Experiments with an ATX power supply martinab2 Solid State 0 29th March 2004 10:04 AM
Copyright ©1999-2017 diyAudio
