Old 22nd December 2005, 07:41 AM   #1
Hara is offline Hara  United States
Hara's Avatar
Default Quick Baffle Question
Lets say you have a lot of space, and you have a small boxed speaker that needs baffle step correction. Is attaching a baffle extension to make the baffle really large a possible, although not necessarily practical, solution? Sort of a open baffle + boxed speaker design?
I'm concerned about a particular project of mine, I had some construction problems and have to make the baffle slightly larger although the internal dimensions remain the same.
I'm curious of the effects of making the baffle larger in the dimensions of width and height while internal enclosure dimensions remain the same.
Old 22nd December 2005, 09:09 AM   #2
yes, a large baffle will lower the baffle step in frequency,
until with a very large baffle its academic due to the box
bass roll off or the interactions of bass with room nodes.
Still usually much better to get rid of the box, unless the
driver has a low Q requiring a box smalller than its Vas.
/sreten.
Quick quick question ! guitvinny Pass Labs 6 7th February 2007 04:20 PM
A quick THD+N question SamM Analogue Source 4 9th October 2004 01:34 PM
Quick question.. bafke Multi-Way 5 11th November 2003 02:47 PM
Page generated in 0.07745 seconds (70.70% PHP - 29.30% MySQL) with 10 queries
