Hello everyone,
I recently bought some 15" Zeuz PA speakers (type 15 400 HC), and measured the t/s paremeters: Fs: 33.5 Hz Qms: 5 Qes: 0.75 Qts: 0.65 Vas: 304 L The drivers will be used for discoboxes, but I'm not sure what type of enclosure to use (high qes and qts...). Does anyone have a suggestion? best regards Erwin |
#2 |
Did it Himself
That's a very high Qts, you will be restricted to sealed boxes, unless you can tolerate an absolutely massive box. You might be able to salvage something using a vented box with QB5 alignment. See the ESP website article.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#3 |
#4 | |
But I've got one question: Is a TL system less efficient than a sealed system or not? regards Erwin |
#5 |
As far as I know it has no influence on the directly radiated higher frequencies.
#6 |
In that case it's worth a try. Everything will be an improvement when listening to these drivers in sealed boxes, because the bass is really bad... No low end at all.
regards Erwin |
| Changing enclosure type? | Johnnz | Multi-Way | 1 | 8th August 2008 10:53 PM |
| what type of enclosure is bazooka? | fossilfool | Subwoofers | 8 | 28th November 2005 04:43 PM |
| Page generated in 0.06583 seconds (81.68% PHP - 18.32% MySQL) with 10 queries |
