Do I need to brace?
Do I need to brace?
Old 19th December 2005, 03:29 AM   #1
AutoAudio is offline AutoAudio  United States
Default Do I need to brace?
Would you guys recomend bracing a box thats 3 cubes sealed? I'd rather not, but.. if I got to. Its deminsions are 21.5x17.5
Old 19th December 2005, 10:29 AM   #2
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
With a length like that -yes. Sorry. You could get away without it, but vibration could become a problem. If you're worried about fancy techniques, just use some 3/4" or 1" dowel-rod cut to the appropriate size. Should do the job.
Scott
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 19th December 2005, 11:21 AM   #3
ron.eddy is offline ron.eddy  United States
ron.eddy's Avatar
Send a message via ICQ to ron.eddy Send a message via MSN to ron.eddy
I agree, vibrations could be a big problem depending on the woofer you use. What I usually do, since I hate bracing, is make one additional front panel (assuming your front is inset) and cut an identical hole in the middle as you did for the real front, then just put it in the middle of the box. As long as you are working with the table saw anyway its no big deal. The real problem comes when you don't have enough wood on the one sheet for it and you have to go buy a whole new sheet...
Although, I found one site saying you don't need to add bracing for boxes under 5 cubes (which I personally disagree with):
http://www.termpro.com/articles/buildbox.html
- Ron
Old 19th December 2005, 12:49 PM   #4
Scottmoose's Avatar
Good technique. Can't say I agree with that link either. Mind you -with a few exceptions, I can't say I ever really associate car-audio with 'high-end' anyway.
Old 19th December 2005, 03:49 PM   #5
Geek is offline Geek
Geek's Avatar
Depends on materials too. Stuff that size I never braced, but I also used 1" MDF. But that's just crazy ol' me
Do I need to brace?Hide this!Advertise here!
Holey Brace Design 901Fixer Multi-Way 10 5th July 2009 04:28 AM
2x4 brace matrix curiousburke Subwoofers 3 7th December 2007 03:40 PM
Cabinet brace act as helmholtz resonator? RyanW Multi-Way 17 3rd October 2007 12:08 AM
which is the best type of corner brace ? busterno1 Multi-Way 1 1st February 2004 11:34 AM
Cross brace not working Kanga Multi-Way 23 3rd April 2003 07:19 PM
Copyright ©1999-2017 diyAudio
