Old 18th December 2005, 01:33 PM   #1
Default substituting 4ohm for 8ohm midbass driver
Hi all,
say I want to replace an 8 ohm midbass driver with a nigh
on identical unit but it has 4 ohm nominal impedance.
I have the crossover details for the 8 ohm unit. I don't think
I should simply scale the crossover parts to 4 ohm because
isn't the real issue the inductance of the drivers ?
So my question is : what would be the typical difference in
inductance of 8 and 4 ohm versions of the same driver ?
(no sensistivity issues as the tweeter has an L-pad)
/sreten.
Old 19th December 2005, 01:27 AM   #2
Volenti is offline Volenti  Australia
You will need to modify the x-over to suit the 4 ohm impedance, the inductance of the driver does play a role but it's not primary one.
I would assume the 4 ohm version would have a lower inductance all else being equal.
8ohm speakers 4ohm tap 5u4 Tubes / Valves 1 17th April 2009 11:22 PM
4ohm and 8ohm LR4 xo LukeDuke Multi-Way 1 17th April 2008 05:09 PM
8ohm or 4ohm? adrrad Chip Amps 5 21st October 2007 04:29 PM
Can a 8ohm driver be mated with 4ohm tweeter? Nordic Multi-Way 10 2nd October 2007 11:53 AM
4ohm Sub driver to 8ohm Sub amp? WBFAir Multi-Way 10 31st March 2007 01:29 AM
Page generated in 0.07068 seconds (67.47% PHP - 32.53% MySQL) with 10 queries
