Old 16th December 2005, 08:40 PM   #1
smak is offline smak  Canada
Default dipole with non intentical drivers..
i went and picked up another pair of pyle ppa15 drivers to fill out another channel in my stereo sound system but to my dismay the model seems to have been revised.
my origionals had a regular black paper cone and slightly larger vent area over the voice coil.. the new ones have some sort of textured coating over the back of the cone (although its still paper) and the front has alot more gloss to it. much stiffer cone, although part of this may be because my origionals have been broken in over the past year in a mono w-frame.
would it still be a good idea to use them in my setup? i figured i would have one of the newer subs facing forward coupled with an older one facing back in the first h-frame (polarity reversed) and then the opposite on the other side to maintain cancellation benefits.
or should i just bite the bullet and get another 2 of the newer drivers and ditch the old ones altogether?
Old 16th December 2005, 08:45 PM   #2
Did it Himself
richie00boy's Avatar
Surely all you need to do is use the old ones as a pair push-pull on one side and the new ones on the other side
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 16th December 2005, 08:59 PM   #3
but then the channels will sound different.
at least by mixing up the drivers a bit it blends the differences a bit no?
Old 17th December 2005, 10:05 AM   #4
Did it Himself
The wavelengths of the bass reproduced by the bins will be so long that the blending of the sound will be done simply by playing them in a room.
If you pair up the drivers as you suggested they will not function as true dipoles as they won't exactly complement each other.
Old 17th December 2005, 01:56 PM   #5
Rudolf is offline Rudolf  Germany
Rudolf's Avatar
You won´t get the (purported) cancellation of harmonic distortion, but apart from that every driver will work as a dipole on its one. For best acoustic balance I would pair different drivers in each h-frame.
www.dipolplus.de
Old 18th December 2005, 07:26 PM   #6
opp is offline opp  Denmark
opp's Avatar
Re-use the old ones – absolutely. And use the saved money for eg. larger a power amplifier. Agree with Rudolf - symmetry crucial.
time flies like an arrow ... and fruit flies like a banana
Old 19th December 2005, 03:16 AM   #7
ugh, i've got all the power i can handle for now..
maybe i can find a new home for the old drivers to cover some of the cost of the new..
something about having two channels with different characteristics doesent sit well with me..
thnx for the replies guys, i'll swap the drivers around until the new ones are purchased.
p.s. any torontonians or ontarians want to purchase two broken in 15" dipole subwoofer canidates?
equipment - dipole drivers bvd65 Swap Meet 1 3rd November 2007 07:48 AM
PHL Drivers for a Dipole ScottTracy Multi-Way 2 4th May 2007 10:11 PM
Drivers for dipole sub up to 200-300Hz swak Subwoofers 23 15th November 2004 06:57 AM
Dipole Using $.69 drivers DougL Multi-Way 5 26th September 2004 01:50 AM
Page generated in 0.08282 seconds (84.54% PHP - 15.46% MySQL) with 10 queries
