This may be a very dumb question, but why does the winISD response fall of so very far short of the FR125S published response?
#2 |
winisd
#3 |
diyAudio Moderator Emeritus
The low end conditions of the published graphs are unknown. I wouldn't compare low end response with that graph for sure
Best thing to do is measure the nearfield response of your design and then compare to winisd to see if there is any discrepency.
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.) |
#4 |
The measured response is on an IEC baffle. This is a big baffle with no rear chamber on the driver. The driver will play down to its resonance and then roll off. When you put the driver in a sealed box, you increase the resonance of the system - the air spring of the box makes the entire 'suspension' of the system stiffer than the speaker's suspension alone, so the resonant frequency goes up compared to just the driver.
#5 |
It's the non-existant top end in the winISD model that's confusing me.
I took some test tone readings with a SPL meter but they were all over the place, and moving my head I could hear really bad destructive interference. I guess this is reflections? I knew my room was bad for echos. So how should I measure? TrueRTA and pink noise? |
#6 | ||
Oh, that's just the rolloff due to the Le you entered that WinISD is showing. It has no other information, like narrowing of the polar pattern and cone breakup caused by cone material properties and cone shape, so it can't predict high frequencies any better than what it does. Quote:
#7 |
Hi Jim, just to put it in a different way, T/S modelling apps are to model low end response only.
| Effect of exceeding XMAX in real life | jondoe | Multi-Way | 18 | 25th May 2005 05:40 AM |
| Room Gain in Real Life | richie00boy | Multi-Way | 21 | 17th May 2005 06:17 PM |
| Chess In the Real Life | Jay | The Lounge | 3 | 1st April 2003 07:31 AM |
| Page generated in 0.09458 seconds (74.83% PHP - 25.17% MySQL) with 11 queries |
