RECENTLY I USED>>AUDIO TESTER<<TO MEASURE MY CAR AUDIO
DRIVERS' P/S PARAMETERS,BUT I GOT 600% ERROR IN IMPEDENCE ,WONDERED Y?CAN ANY BODY TELL? THANKS! PS:SOUND CARD OUT MATCHED AMP THEN DRIVER,DRIVER CONNECTED WITH 3 OHM CERAMIC RESISTOR IN SERIES,RESISTOR PARALLELLY PLUGGED WITH SOUND IN. ALSO TRIED TO CONNECT WITHOUT AMP.BUT DIDN'T WORK. |
#2 |
Speakerholic
First, please don't type with the caps lock on.
Second, have you tried removing the driver and measuring the DC resistance? |
#3 |
yup!that's what i want to supplement,DC resistance was 3.2 ohm,
specified Rnom was 4Ohm,anyway it's impossible to be over 20 Ohm.and i measured Rnom was 24.xx Ohm, #_#!! |
#4 |
perhaps you're measuring the impedence peak at resonance
The golden rule of DIY: Build nice, or build twice! |
| Marantz CD63 KI SIG, Error 12, Sled Error problem | sisik | Digital Source | 1 | 9th November 2008 03:12 PM |
| Where is the error with this ohm's law calc? | riotubes | Parts | 19 | 24th November 2006 05:33 PM |
| Spice Error | bembel | Tubes / Valves | 2 | 8th November 2006 02:45 PM |
| Whats worse, 1db error in response curve or a phase error of 6? | primalsea | Multi-Way | 5 | 13th May 2003 01:24 AM |
| Page generated in 0.08331 seconds (69.18% PHP - 30.82% MySQL) with 10 queries |
