#11 | |
Imagination is more important than knowledge. knowledge is limited, imagination encircles the world. Albert Einstein FrankDIY's Audio Corner |
#12 |
Francois:
Please post for all to see the capacitance/inductance/resistance change of typical crossover component values as a function of a reasonable ambient temperature range within a typical enclosure. A series of graphs would be nice but a table will suffice. Thank you. |
#13 |
I don't think heat has anything to do here. More the vibrations and resonances. Ever poked your head inside a speaker cabinet while the drivers were playing music? I did, and didn't like it at all.
Also, it's been shown, that even CD players sound better without cover.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#14 |
I agree with Peter, isolating the crossover components from the vibrations of the driver has a perceptable effect. Since I discovered this I have always mounted my crossovers externally, in non ferrous boxes.
Peter- did you used to stick your head into the bass bins at live shows too?
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#15 |
Interesting discussion.
Everybody has their own opinion on these parameters since it is almost impossible to objectively measure the difference. Sounds different? Maybe. Sound better? [put your answer here]. Heat can be as important as vibration (especially if your connection are loosy
#16 |
François, one advantage of having your crossovers external is that if you have an unearthed soldering iron, you can change crossover values on the fly, and fine tune it much more easily.
Some very expensive loudspeakers run external crossover boxes. Eric. |
#17 |
Exactly, it is very useful in the debugging and tweaking phase. Also it is a good advantage because you can show the crossover to your others audio freak friends.
#18 |
mrfeedback wrote "change crossover values on the fly"
is this recomended? with solder, wire, othr caps etc. i would prefer to turn the power amp off.
...still looking for the holy grail. |
#19 |
If you add a switch in series with the earth connection to the tip/barrel of your solder iron, and run your amp at low to medium levels and are careful not to cause any short circuits, you can solder in or delete components whilst you are listening and compare the results in real time.
I have done this on circuits for years and no problems. Eric. |
#20 |
oups, I have never did that real-time
| Mains hum on a guitar effect unit! Help (circuit enclosed) | HankMcSpank | Solid State | 10 | 18th March 2009 12:44 PM |
| can a enclosed bookself speaker be mod to a ported type to improve bass response | joker6211 | Multi-Way | 8 | 6th July 2007 06:22 AM |
| unknown peerless enclosed mid | Mark25 | Multi-Way | 5 | 11th June 2004 07:35 PM |
| would it be okay if I spray paint an enclosed transformer? | jarthel | Everything Else | 1 | 21st June 2003 05:19 PM |
| Page generated in 0.14794 seconds (65.15% PHP - 34.85% MySQL) with 11 queries |
