looking to build a high efficency, small speaker. - Page 2 - diyAudio
Old 16th December 2005, 10:32 PM   #11
demogorgon's Avatar
Send a message via MSN to demogorgon
damn, thats a pretty efficient 6' that one..
to bad about the Fs of 120
(and the 2mm xmax )
this one however, seems to be worth investigating
-Marius
Old 17th December 2005, 08:20 AM   #12
frugal-phile(tm)
planet10's Avatar
Default Re: How high?
Originally posted by joe carrow but size and efficiency really are hard to have together.
There is an Sd term in the equation for efficiency... smaller driver, less efficiency.
Bipoles have no baffle step -- it is inherent in the physics.
If you are considering the W3-871 you also need to look at the Aura NS-3. Neither gets anywhere close to the efficiency required.
My 1st thot was Fostex FE127.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 17th December 2005, 12:06 PM   #13
T/S-parameters for higher sensitivity:
High: Fs, Vas, Bl, Sd. Low: Qes/Qts, Re, Mmd/Mms
Wkr Johan
Old 17th December 2005, 12:43 PM   #14
demogorgon's Avatar
Default Re: Re: How high?
dave
I'l look into bipole construction, but i dont hink it's feasibe in this scenario. to big and i'm counting on bassreflex to straighten up the bottom end curve, i want this speaker to be linear for as long as it can.
the Aura NS-3 is at a 80db\1w, way to low for me.
I was considering the W3-871 in a possible dual\triple arangment, but until Chris clairify on "lobing" the fullrange option is out.
thanks for your input though
Wkr Johan
Johan, thanks, but why just not look at the respons graph and the db\1w?
Old 17th December 2005, 01:48 PM   #15
AJinFLA is offline AJinFLA  United States
Banned
If your amp is ok with lower impedance loads then run 2 of these in series mounted bipole in a small enclosure.
http://www.crutchfield.com/S-V2p3igg...i=108327CF#Tab
Around $70(ea. pair) on ebay puts you well inside your budget
http://cgi.ebay.com/Infinity-Kappa-3...QQcmdZViewItem
The neo magnets also reduce weight. Email Infinity for the T/S data.
You may have a dealership that has these that you could go listen to them (unlike many of your other options). They sound pretty good to me. They have (real) treble that a fullrange driver can only dream of (I own several TB's). Good luck.
AJ
disclaimer: This is my opinion. I don't care what anyones opinion of my opinion is - other than the original poster.
Old 17th December 2005, 03:26 PM   #16
frugal-phile(tm)
planet10's Avatar
Default Re: Re: Re: How high?
Originally posted by demogorgon
I'l look into bipole construction ... too big,
Anytime you start considering 2 drivers, a bipole is a serious consideration. No BS, no combing, same box volume.
dave
Old 17th December 2005, 03:54 PM   #17
but why just not look at the response graph and the db\1w?
If you recalculate the sensitivity it will mostly appear to be a few dB less, sometimes more than that, sometimes less.
More reliable is the n0, sensitivity is derived from n0 anyway.
Easy to apply is: n0 (%) = 9,6 x 10-8 x Fs^3 x Vas /Qes
The response chart is nice but sometimes optimal designs are used that are unrealistic for the actual use. Always read the small-prints.
Recalculate Xmax as well
Wkr Johan
Old 17th December 2005, 04:01 PM   #18
demogorgon's Avatar
AJ
AJ!
Well, i supose they'r ok, i have no "beef" with car equipment, but i suspect the "sensitivity" is measured at 2.8V, and then it kind of looses it's meaning
thatl translate to 89db\1w, nothing short of average.
i saw the same done at seas with the performance 6.5'inch. 94.5db\1w just sounded to damn good to be true the real efficency was 91.5
thanks for you reply though
-Marius
Old 17th December 2005, 05:37 PM   #19
demogorgon's Avatar
Wkr Johan
Johan!
you are right offcource, but i thought all respons chats are made in anorechtic chambers?
Old 18th December 2005, 11:49 AM   #20
VvvvvV is offline VvvvvV  United Kingdom
Small full range drivers on modern micro hi-fi's sound pretty amazing, especially in the midrange. gets a really good 5" full range. I would be tempted at doing some kind of foldaway design.
You might even consider a micro transmission line with something so small like that all the efficiency is transferred into bass . Perhaps you could use some PVC gas pipe because it sounds a lot better than wood with something that size.
You could even buy a malfunctional micro hi-fi online and just keep the speakers and the amplifiers and turn it into a micro transmission line.
[noob] Looking to build a really, really small sub Lindell Subwoofers 18 13th November 2007 04:16 PM
8" high efficency woofers - NEED HELP Miha Multi-Way 9 28th February 2007 02:43 PM
Want to build small subwoofer c3ham Subwoofers 76 7th September 2006 09:26 AM
build my first full ranger,let's build another one:a small fullrange high end pc-spea then_dude Full Range 2 30th November 2005 08:54 AM
How inexpensive can you build a small 6-ch amp? mazeroth Chip Amps 9 6th November 2005 04:48 PM
Copyright 1999-2017 diyAudio
