Hi everyone :-)
I need to replace a broken 1 3/8 horn driver from a cheap PA speaker. The driver has no name on it, so i took it apart to se what kind it was. Inside it looks like there a both a piezo element glued to a diaphrame and a voicecoil ? There is no magnet. How can that be ? What kind driver is this ? Is it a Piezo ? Kind regards, Stormo. |
#2 |
Speakerholic
I'm not familiar with your description. Can you post some pics?
#3 |
#4 |
Speakerholic
If it is a piezo, you might consider stepping up the quality a bit. IMO the only thing more irritating than a piezo is a compression piezo. Are there two speakers? If so you'll have to buy two anyway as you won't be able to match the sound of old and new very well.
#5 |
Thank you for the replys - Hornlover you found the rigth one !!!
Now i need to find a place in Denmark to buy.. Hmmm ? Kind regards, Stormo |
| Single Driver Horn Base Port from Frugal Horn | EmergencyDpt | Swap Meet | 0 | 26th October 2008 01:24 AM |
| need remedy for driver's broken connector | bonjonno | Multi-Way | 3 | 28th February 2008 05:00 PM |
| Crisis! need to replace 15" driver - Gig tomorrow!! | Pbassred | Multi-Way | 3 | 21st March 2005 06:20 AM |
| Mark Levinson JC-2 problem ( broken Line driver ) | ken1967 | Solid State | 4 | 30th December 2004 10:16 AM |
| I want to install a new woofer driver into my old broken speaker. | S.C | Multi-Way | 18 | 25th September 2003 05:40 AM |
| Page generated in 0.07658 seconds (70.12% PHP - 29.88% MySQL) with 10 queries |
