I'm a novice for Speaker DIY and just get a membership especially to ask this question I saw some thread discuss about matching these 8530 + XT25. I really interested to build a pair of this, but not sure yet which schematic should I start with ? please advise many thanks
#2 |
I came across this post once
http://www.fsec.ucf.edu/download/Tem..._XT_X-over.JPG I have tried it, but had to change the values some to make it fit my taste better. with C2= 17.5 uf C1= 6.5uf and R1=2.8 ohm You should try it, it performs very well. I have dokumentet my project, but the language is in Norwegian. However you should be able to see the pictures. Best Regards http://www.hifisentralen.no/cgi/yabb...7819063;start= |
#3 |
bambadoo,
Thanks for a good advice, your cabinet look really nice. I will start with the value that you posted and will try to varie between this one and the original one. One more question, what is the box volume & port dimension you've used ? best reagards 100db |
#4 |
The box volume is approx 7l and the port dimension is 4.6 cmX10 cm.
Best Regards |
#5 |
Again, thanks for sharing this.
| GR M-165x/Vifa XT25 2-way | TurboFC3S | Multi-Way | 0 | 17th July 2007 12:37 AM |
| WTB: Vifa XT25 | Tristanc1 | Swap Meet | 0 | 13th March 2007 06:44 PM |
| Vifa XT25 | Jonasz | Multi-Way | 30 | 19th January 2007 06:18 AM |
| Vifa xt25 & p13 | Gavinator68 | Multi-Way | 1 | 1st June 2005 07:39 AM |
| Vifa xt25 question | Clueless | Multi-Way | 8 | 10th September 2003 10:00 AM |
| Page generated in 0.08100 seconds (72.39% PHP - 27.61% MySQL) with 10 queries |
