Old 14th December 2005, 10:44 AM   #1
opp is offline opp  Denmark
opp's Avatar
Question Experiences with the Tang Band 8” driver?
I’ve been searching the forum for posts regarding experiences with the Tang Band 8” driver (W8-740E to be precise). There are some, but it is unclear to me if anyone has any real experience with the driver.
I am considering using it in a dipole project, 3 per side in series with active xo and eq (F ox 200/250 Hz) . The advantage of this driver is its price and size. I know its low Q requires a lot of eq. but I don’t see that as a problem, as I am only requiring moderate SPL.
Can these small drivers produce real HIFI?
time flies like an arrow ... and fruit flies like a banana
Old 14th December 2005, 10:52 AM   #2
indoubt is offline indoubt  Netherlands
indoubt's Avatar
Are you sure your looking for the "E" version? It looks like you mean the "C" version where there is plenty on this website
The C version goes lower in smaller boxes if I recall correctly
better be indoubt untill you're sure
Old 14th December 2005, 11:42 AM   #3
opp's Avatar
It is in fact the E version; the reason is that a Danish distributor has a good offer on it. But any general experience on the TB W8-740 series should apply to the E version – was looking for that as well.
Old 14th December 2005, 04:00 PM   #4
Speakerholic
Cal Weldon's Avatar
The rubber surround E version wasn't available at the Canadian distributor so I bought the foam surround C. It's quite a nice little driver. Good depth, nice beefy motor. I use mine with two drones per cabinet so I wouldn't be helpful with your setup. I agree though that the Q being that low it will require huge amounts of EQ.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Exiting new 4 inch FR driver from Tang Band? Fast1one Full Range 1 21st May 2008 07:28 PM
Tang Band FR Project Using A Titanium Driver JimOfOakCreek Full Range 6 15th April 2008 09:40 AM
new Tang-Band driver dmitriy167 Full Range 8 25th June 2004 01:16 PM
Tang Band driver opinions Jared Multi-Way 37 12th June 2003 11:19 PM
Experiences with Tang Band speakers! Help me, Hilfe Mich, Au Secours! Nathan Multi-Way 11 26th April 2003 01:25 PM
Page generated in 0.06699 seconds (71.65% PHP - 28.35% MySQL) with 10 queries
