Old 14th December 2005, 01:56 AM   #1
yertzl is offline yertzl  Australia
Send a message via AIM to yertzl Send a message via MSN to yertzl Send a message via Yahoo to yertzl
Unhappy newb starting on SW
hey yeah. im trying to wrap my head around everything at once. and ive got the speaker workshop manual 1.0 from jay butterman. very good stuff.
anyway was wondering about this preamp for the measurement microphone.
i dont really know anything about amplifiers.
i think this preamp stops the soundcard from been fried so i want to use 1(im not very computer literate either but i can follow a manual).
anyway where does one get this preamp from.
in fact any basic start of hints would be helpful.
im going to go and build this jig now wooooot.
Old 14th December 2005, 03:55 AM   #2
Default schematics
actually if some1 could post a link to schematics of a pre-amp and testing mic that work together it would be much appreshiated.
ive done a search on diyaudio and its just info overload!
Old 14th December 2005, 02:10 PM   #3
claudio is offline claudio  Italy
claudio's Avatar
the preamp is for the mic, therefore is needed for the acoustic measurements, and as nothing to do with frying the sound card: instead of building one, you can buy Behringer UB802 and the ECM8000 as microphone. They are cheap. In case you want to build a preamp, remember that if you are going to use the ECM8000 mic, it needs phantom power and a balanced input. Here there are schematics for the mic preamp, but I think it's on the Manual too:
http://mysite.verizon.net/tammie_eric/audio/audio.html
Claudio
Old 15th December 2005, 12:10 AM   #4
thxs claudio.
ill probable make the preamp1 (cant pull up num#)
and still look for a mic 2 build. for they cost $US50 plus shipping.
i can buy electret mic inserts from altronics. this is the best 2.
polar pattern: omni-directional
current drain: 0.8mA max
impedance: 1kOhm+-30%
sensitivity: -60dBm+-3dB
freq response: 50-13kHz
cost: $2.30
sensitivity: -55dBm+-3dB
freq response: 20-10kHz
cost: $2.30
slight diff in freq resp and sentitiviy
and ive seen some home made ones on the net cant remember where.
trying to keep costs down. half the reason i wish to build speakers
Old 15th December 2005, 12:47 AM   #5
rjb is offline rjb  New Zealand
Try Elliot Sound Products in Australia for a simple mic preamp- he sells PC boards. Use Google
Old 15th December 2005, 02:06 AM   #6
NickZ is offline NickZ  Canada
Originally posted by claudio
[B]Hi,
buy Behringer UB802 /B]
Is there any reason the Behringer UB502 wouldn't work? It's cheaper-)
Nick
Old 15th December 2005, 01:42 PM   #7
claudio's Avatar
UB502 doesn't have phantom power.
yertzl, the most used mic capsule, for measurements, are the Panasonic WM60 and WM61; you can find them at Digikey and Monacor catalogue.
The ones you showed have limited frequency response.
If I remember well, in Linkwitz home page there is a modification for the Panasonic capsule, as well as on Elliot's page: http://sound.westhost.com/project93.htm
Claudio
Old 15th December 2005, 06:34 PM   #8
Vikash is offline Vikash  United Kingdom
diyAudio Moderator Emeritus
Vikash's Avatar
http://www.madaboutsound.com/prod.asp?pname=MPK
I don't have the kits available, only the PCB's at the moment (can't find a source of the LM6134AIN opamp). But if you want to do it yourself, then the PCB is cheap as chips.
For a mic you want the Panasonic WM-61 electret. Those are on the site too. And don't worry about mods to the capsule.
If you fancy building the mic preamp pcb yourself, then look up the Wallin Mic Preamp v2.
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.)
Just starting GrooveCat Introductions 4 11th January 2008 02:37 PM
Just Starting out Freestyling Introductions 6 9th November 2007 08:38 AM
starting out ineedahobby Chip Amps 3 15th October 2007 08:31 PM
Starting AMp up Wynand Chip Amps 2 25th August 2005 02:57 PM
starting over again... help! fazman Subwoofers 6 25th May 2005 08:26 PM
Page generated in 0.11285 seconds (80.03% PHP - 19.97% MySQL) with 10 queries
