Two identical drivers
Old 12th December 2005, 05:18 PM   #1
HogieWan is offline HogieWan  United States
Default Two identical drivers
I know most people like answering specific questions, but I've got a hypothetical one.
If I put two identical wide range (~80-15kHz) drivers in a box, what are the pros cons of (a) running the same range to each driver or (b) splitting the signal and let one emit the higher half of the range and the other take the lower half?
Old 12th December 2005, 06:15 PM   #2
JohnSz is offline JohnSz  United States
C) Run both drivers upto the crossover point, where the upper one would produce only the high frequencies. Crossover point to be determined by distance between drivers.
I believe this is what is typicallly done. Read up on full-range drivers, etc.
JohnSz
Old 12th December 2005, 06:38 PM   #3
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
HogieWan,
You might want to try what John has said. Rather than run one high and one low, run one full range and the other you cut off the high end. This will give you greater bass output.
Having said that, it's only a guess as it really depends on the drivers. Why not experiment?
planet10 needs your help:
Let's help Ruth and Dave
Old 12th December 2005, 08:10 PM   #4
rjb is offline rjb  New Zealand
a) If you run both drivers over the same range you will get the same performance as one driver only, except the nulls and dips in the frequency range will tend to be emphasised, (refer MarkMck's site), and you will get better power handling. However it can sound like a multiple source, and the upper frequencies suffer if the drivers are big.
b) if you run one driver low and the other high the crossover point is not easy to get perfect, but you will get better clarity as the bass load is taken off the high range unit. There is no other advantage in terms of power handling, in fact the efficiency is reduced and the cost/complexity increased.
c) the single full range plus bass only arrangement provides better power handling in the bass, where it is needed, increases bass output, so can be used to compensate for shortfall there, yet retains the single source for higher frequencies. It is really a compromise between a) and b)
The best approach tends to depend on the driver size and the crossover point. For example small Jorden's and Bandors run type a), but are then best combined with crossover to a larger low range unit in the one/two hundreds to provide better bass performance and power handling. Jorden 4 inchers can be run both full range, sometimes with a helper tweeter,however in my opinion those I have heard have not sounded as good as a single unit on voice and small instumentals, but better on heavy orchestral.
Larger drivers, say above about 6 inch, generally to go for type c).
I am not aware of any commercial units that go for b), although there are some that use two identical bass/mid units arranged as bass only/mid only plus tweeter for the very highs.
Two identical driversHide this!Advertise here!
Two IDENTICAL units, different sound!?!? bear Digital Source 25 30th June 2009 06:34 AM
One B+ for the both driver and output tube if they are identical? vhrynchuk Tubes / Valves 5 26th August 2006 01:54 AM
Is this driver identical to the FE-103? bigwill Full Range 7 1st May 2005 05:33 PM
Two identical drivers in one enclosure: Implications dumrum Multi-Way 3 31st March 2004 08:14 AM
What would be the effect if 2 identical drivers are ...? Lito Multi-Way 1 13th October 2003 09:42 AM
Copyright ©1999-2017 diyAudio
