Hi All
I need some help planning cabinets for my new project. I'll use a simple pc + rme pst to run BruteFIR as a digital filter, it's all ready, fully functional and tested. I'll use an old stereo ONKYO receiver as the amp for the woofers and two t-amps for mid and tweeter. I plan two boxes for each speaker, one for woofer and one for tweeter/mid. Chapter 1, Planning the Woofer: The woofer is a 10" morel drive, mw1075 - (http://morelusa.com/woofers/mw-1075.htm) For the woofer I'll build a sealed box, in an infinite baffle fashion. Working material is 2x17mm fly wood (red fly wood), the inner walls padded with damping material. H: 108 cm (42.5") W: 40 cm (15.75") D: 25.4 cm (10") Are these measurements good? Where should I place the woofer? middle? upper middle close to the other box with the mid/tweeter? My only limitation is the size of the wood planned for the job, it's 2 plates, around 120x240cm (4x8 feet) Preferred shape is rectangle (off course), I'll probably trim the edges in a 45 degree angle to soften the edges. Is it better to round them? 45 degrees are much easier technically… Thanks for your help. |
| Morel CAW 938 vs. Peerless Exclusive 8'' for MDM 55 and OW I Project | leifislive | Multi-Way | 17 | 3rd March 2009 06:07 AM |
| My TL/Bi-Amped Powered Speaker Project | Nedrex | Multi-Way | 14 | 18th February 2009 01:08 AM |
| new morel MTM project: rantings | wintermute | Multi-Way | 22 | 30th January 2005 11:13 AM |
| Where to place the amps in bi-amped/tri-amped | Xicarius | Everything Else | 1 | 4th August 2004 12:13 PM |
| Help with Morel sub project | andrew | Multi-Way | 5 | 11th May 2002 02:29 AM |
| Page generated in 0.07431 seconds (63.00% PHP - 37.00% MySQL) with 10 queries |
