Old 12th December 2005, 12:14 PM   #1
bluetomgold's Avatar
Default 8" Woofer Recommendation (UK)
I'm looking for an inexpensive driver to use in a smallish sealed box 2-way speaker project.
I know what I'm looking for but was wondering if anyone has experience with cheap drivers available in the UK. I have access to a CPC account.
Here's what I want:
- 8" Midbass Driver,
- Paper cone (preferably raw/untreated paper but reasonably thick and stiff)
- Foam Surround (preferably not too thick - nice and compliant)
The main attributes I'm ideally looking for are a low Q, high efficiency and smooth midrange response that rolls off quickly somewhere between 1 and 2 khz.
If anyone has any ideas I'd be happy to hear them!
Old 12th December 2005, 01:08 PM   #2
you could check out the new cheapo chinese drivers in Maplins.
I think 8" drivers start at £14.
As far as I know foam surrounds are not good for smooth midrange,
though they are good for dynamic bass - and the opposite applies
to rubber / pvc surrounds - good midrange termination but limits bass.
(though the above is a generalisation, may not apply to cheap drivers)
/sreten.
Old 12th December 2005, 03:13 PM   #3
Mutley666's Avatar
You could try "West London Electric", they have some cheap kevlar and PP coned drives.
There appear to be no FR plots available, but there is a pdf containing the T/S specs available on the www.skytronic.com website.
Try this link and have a look at the PP cone and Kevlar cone drivers, they realy are cheap;
Old 12th December 2005, 04:22 PM   #4
They certainly are cheap. Look like the same drivers CPC sell, also available in the US as MCM (I think). I was specifically looking for a paper cone and a foam surround though.
I'd be interested to try something with an old fashioned ('60s Acoustic Research style) treated cloth surround but as far as I can tell there's nothing like that produced any more. Unless anyone knows otherwise...
Sreten - what you say regarding foam vs rubber is pretty much right, I think. What I meant though, was those were the attributes I desired from a foam-edged, paper driver - bass speed/agility are (hopefully) a given. In other words - as smooth a midrange as is possible from a driver of this type...
Anyway, what I really want is a simple, lightweight driver with good basic mechanical properties which (if required) I can then modify by hand with damping and doping etc. I want to experiment, and I'd rather have (mostly) organic materials as a starting point.
Old 20th December 2005, 08:17 AM   #5
The 10L box tuning frequency is 28Hz - seriously overdamped tuning.
/sreten.
Old 20th December 2005, 10:11 AM   #6
Hi, sorry replied to the wrong post,
please delete this and the above post,
/sreten.
Woofer recommendation cs Multi-Way 2 13th November 2007 10:48 PM
Dipole Woofer for upper bass Recommendation Hara Multi-Way 5 11th June 2007 07:39 PM
Woofer recommendation mbrennwa Multi-Way 0 27th March 2005 11:13 AM
WTB: Focal & Audiom & Volts 11", 12", 13", 15" woofer gengis Swap Meet 0 17th March 2005 02:29 AM
Recommendation for a "metal" speaker? mazeroth Multi-Way 1 19th February 2005 01:58 AM
Page generated in 0.08557 seconds (76.45% PHP - 23.55% MySQL) with 10 queries
