Old 12th December 2005, 01:35 AM   #1
andy2 is offline andy2  United States
Default Which cap would help reduce sibilance?
I recently build a parallel xover version for the Eros speaker but the speaker still have a bit of sibilance that I want to reduce. My xover currently uses Solen but I am looking for something that will reduce sibilance a bit.
Do you think it will be worth it to upgrade the tweeter xover with all Mundorf caps?
Old 12th December 2005, 06:35 AM   #2
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Use SCR tinfoil as the cheapest cap with sweet sonics. Try to evaluate if you miss a little midrange. Missing midrange always tones up treble, and sibilance is tell tale when it is happening.
Old 12th December 2005, 09:27 AM   #3
soongsc is offline soongsc  Taiwan
soongsc's Avatar
Do an impedance test on the system, if there is a peak in the mid range section, try getting rid of it first.
Hear the real thing!
Old 12th December 2005, 11:32 AM   #4
Have you tried adding small bypass caps to the main caps? It may help.
I added 22nf (10nf is recommended with some caps) polys to my crossover caps (SCR and MCAPs) and it made a marked improvement - the sound is smoother and more refined without loss of detail.
Old 12th December 2005, 09:09 PM   #5
Cloth Ears's Avatar
Try checking your actual frequency response first. You'll probably find a peak in the 3-6kHz region. Tame this first by adjusting your actual xover values before you start looking for just changing the cap.
Jont.
"It is impossible to build a fool proof system; because fools are so ingenious."
Fostex Sibilance? wixy Full Range 8 4th April 2008 05:20 PM
Sibilance GOWA Multi-Way 14 9th August 2007 03:01 AM
Sibilance Distortion on SMGs alexmoose Planars & Exotics 5 21st May 2007 09:21 PM
Sibilance problem DerrickM Multi-Way 4 4th May 2007 03:21 AM
Sibilance opus007 Multi-Way 19 12th February 2005 06:23 AM
Page generated in 0.35626 seconds (20.48% PHP - 79.52% MySQL) with 10 queries
