Old 11th December 2005, 01:12 PM   #1
Vikash is offline Vikash  United Kingdom
diyAudio Moderator Emeritus
Vikash's Avatar
Default Irrational ratios/enclosure dimensions
I've updated the standing wave calculator to calculate dimensions based on ratios. I've added one useable ratio so far.
If anyone can help give me other irrational ratios suitable for speaker enclosures in x/1/y format, that would be very helpful.
http://www.vikash.info/audio/standing_wave_calc/
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.)
Old 11th December 2005, 01:47 PM   #2
Geek's Avatar
Very handy. Thanks!
Old 11th December 2005, 09:33 PM   #3
I've had good luck with the cube root of 2;
.794/1/1.26; and variants such as .794/1/2.52.
Old 12th December 2005, 10:33 PM   #4
Vikash's Avatar
Updated with new ratios.
Old 12th December 2005, 11:29 PM   #5
Ron E is offline Ron E  United States
Ron E's Avatar
The square root of 2 is ~1.414, not 1.141.
Usual quoted enclosure ratios are based on:
phi = golden ratio = 1.6180339887499 why do I remember this number to so many decimal places?
1.2
1.25
IMO, none of these is better than any other or any number you could come up with. It makes a lot more difference how you mount your drivers on the baffle (for diffraction) than what the box dimension ratios are. Lining or stuffing in the box is used to damp out the resonances.....
Your app calculates axial resonances, but there are also tangential and oblique resonances, and all are excited differently depending on where you mount the drivers...
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan
Old 13th December 2005, 12:37 AM   #6
Tapered boxes are good too; but these ratios are certainly better than integers, 1/2/2 for example. AND you should also line &/or stuff. Nothin' wrong with belt and braces. And positiong drivers non-equidistant from box edges, (which should have radii > 4 inches) also helps.
But one thing at a time, this is a nifty little calculator.
Old 13th December 2005, 12:53 AM   #7
Cloth Ears's Avatar
1.2
1.25
IMO, none of these is better than any other or any number you could come up with...
Ron,
Agreed. But I tend to use the square root of phi (c. 1.27202) for the front of my woofer and subwoofer boxes as it looks better, rather than for any sound reasons. That way the ratio W/H is 1.618/1 (and when you're looking at it from a standing position, perspective also fools you into thinking it's the same ratio W/D).
Internal standing waves I try to damp out (or confuse) by:
1) damping materials;
2) internal bracing with small (eg 2" or 3") holes in it;
3) internal bracing at odd angles and shapes (eg. dowels of different sizes, braces at 15, 22.5, 30 and 45 degrees).
UNLESS I'm doing a TL...
But, Vikash, I think you've got 1.28 in your calculator anyway - and that's close enough to 1.27202
Jont.
"It is impossible to build a fool proof system; because fools are so ingenious."
Old 13th December 2005, 09:32 AM   #8
frugal-phile(tm)
planet10's Avatar
Nice tool Vikash....
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 13th December 2005, 11:47 AM   #9
Vikash's Avatar
Any input on the default threshold value? How close is too close?
Old 13th December 2005, 12:43 PM   #10
Vikash's Avatar
Added ability to factor ratios.
What's the best way to render a pic on the web these days. Is it somehow possible to output code into renderer that output to a gif or something...
Ratios for internal dimensions of speaker box bm_mode Multi-Way 6 18th July 2008 09:06 PM
Speaker enclosure help, dimensions, ASAP DDRRE Multi-Way 1 1st February 2008 11:58 PM
Aluminum mtm enclosure dimensions icanryme2002 Multi-Way 4 27th July 2007 07:46 PM
struggling with enclosure dimensions hotchin2k Subwoofers 10 26th May 2005 05:07 PM
enclosure dimensions and freq. response AudioGeek Multi-Way 3 9th May 2004 07:16 PM
Page generated in 0.10595 seconds (77.61% PHP - 22.39% MySQL) with 10 queries
