Old 10th December 2005, 01:11 PM   #1
Default TMM vs. MTM.............
I am designing a 2.5 system with the Peerless 830875's and Vifa XT25. Is there any difference between the MTM vs. TMM layout? What are your thoughts on this?
David
Old 10th December 2005, 03:01 PM   #2
mazurek is offline mazurek  United States
If I understand correctly, TMM will give more uniform dispersion. And MTM will help minimize floor and ceiling reflections, possibly with wider dispersion, but narrower vertical dispersion.
I would state your application, as one layout would not be inherently better.
Old 10th December 2005, 07:27 PM   #3
LineSource's Avatar
Hi David,
From my understanding of 2.5 way speakers a
T
M1
M2
port
physical topology is fairly common, where the M2 is crossed in down at the baffle step frequency to cover compensation plus the lower bass. I've seen M1 in a separate sealed box volume and M2 in a separate bottom-ported box volume. The bottom port gets uniform floor gain and blocks any direct path to the ear of midrange leakage to help imaging.
A true 3-way TMW or WMTMW with larger diameter W has always sounded best to me. TMW wins clarity and detail. WMTMW wins imaging and weight.
Old 10th December 2005, 09:20 PM   #4
I will be using (2) of the peerless HDS164's and a XT25 in an ported arrangement that will still need a sub in the room for the lowend. The system will need to handle the front two channels of everyday stereo and some occassional HT. The room is a smallish living room with about 200 sq feet.
I was planning on using the HDS134's or HDS106's with an XT25 in a standard, ported two way configuration for small rear HT channels in the future.
For the front channels I was thinking that paralleling the (2) HDS164's in a 2.5 way would make things easier by bringing the 8ohms of the HDS164's down to match the 4ohms of the XT25. Am I missing a more important benefit of crossing them over seperately? I want these to have as much detail and quality imaging as possible.
Am I expecting too much?
Page generated in 0.07489 seconds (74.67% PHP - 25.33% MySQL) with 9 queries
