Hello,
I build a 2 way system speakers, but I don't know where place the midwoofer, above the tweeter (ear) or under the tweeter. The placing midwoofer so high (say around 1 meter from the floor) can "confuse" the image and decrease the impact/slam bass response? Have any advantage/superiority to place the midwoofer high from the tweeter or lower midwoofer height is the best? By the way, the system cross around 2K to 2.5 KHz. Thank you very much. |
#2 |
placement depends somewhat on the vertical polar reponse in the crossover region. Due to phase differences usually one of the above or below axis responses is more consistent than the other and the drivers are arranged to exploit this on the normal listening axis. However it must be said overall box height is a major (domestic) issue consequently the tweeter is usually on top near the top. In extreme cases of inverted drivers the box is placed below the listening axis to generate enough phase path difference between the drivers to allow crossover integration. This does give a domestic friendly height for standmounters. It also should be said exploiting the off axis response in the c/o region usually means losing some of the tweeters top octave response as most tweeters are fairly directional at the top end. |
| 3-way + sub woofer near field "mid" to HI-FI PC speaker system | firefart_1st | Multi-Way | 2 | 9th September 2008 11:07 PM |
| Using a 2-Way System w/ Additional Woofer | TubeHead Johnny | Multi-Way | 5 | 13th December 2007 04:25 PM |
| 2-way System using an 8" woofer??? | nrgy | Multi-Way | 12 | 11th July 2005 06:34 PM |
| Anyone design a system with the Dynavox 28mm tweet and 6.5" woofer? | JCoffey | Multi-Way | 0 | 21st April 2005 02:26 PM |
| Qts of Push-pull woofer and Compound Woofer System... | haggy | Multi-Way | 1 | 13th December 2001 01:30 AM |
| Page generated in 0.07220 seconds (71.40% PHP - 28.60% MySQL) with 10 queries |
