My latest concept
My latest concept
Old 7th December 2005, 02:06 PM   #1
[]0[][]v[][]0 is offline []0[][]v[][]0  United States
Default My latest concept
Hello, longtime enthusiast, first time posting. I came up with the idea of a baffless, and time aligned speaker some time ago after studying Dr. D'Appolito's white paper on geometric design. I followed all of his criteria, including 3rd order crossovers @ ~ 1500 Hz (I know that he has since used 4th order). Amazing what can be had (in terms of value) at such low cost. I used the Dayton Euro drivers, and are amazed with their value. I would put these up against the Vince Christian design anyday. They do require a subwoofer crossed at roughly 90Hz in a larger room (such as mine), but are sufficient in the bass region in a 1/8th space environment.
Benefits would be the peerless (pun to be revealed later on) reproduction of recorded effects, detail, and imaging. I've never heard another speaker reproduce so much of what the recording has on it.
Detractors would be a forward midrange, but if seated more than 10 ft. away this isn't so much a problem (a larger inductor used with the woofers woulda helped). Stupid me sealed the crossover section in the tweeter tube (rookie mistake). Sometimes, these speakers are too revealing on poorer recordings such as anything produced by a rap recording label (except by Aftermath).
Please tell me what you think. I give you the Dayton Sound Tubes!
Here's a pic: http://i10.photobucket.com/albums/a1...d/DSC00071.jpg
and another :
http://i10.photobucket.com/albums/a1...d/DSC00070.jpg
-Thanks
Old 7th December 2005, 02:37 PM   #2
ShinOBIWAN is offline ShinOBIWAN  United Kingdom
ShinOBIWAN's Avatar
Interesting stuff and welcome to the forums.
Old 7th December 2005, 03:03 PM   #3
kingdaddy is offline kingdaddy  United States
kingdaddy's Avatar
I'm a firm believer in baffle-less design as well, it does seem to increase detail and imaging. Nice project, once you get bitten by the DIY bug there is no turning back.
A few of my baffle-less designs
Center Channel
http://kingdaddy.linaeum.com/Center%20Channel/
Mains
http://kingdaddy.linaeum.com/Mains%20(SST-8)/
Old 7th December 2005, 03:46 PM   #4
mrlots2do is offline mrlots2do  United States
mrlots2do's Avatar
Excellent work
Old 7th December 2005, 05:09 PM   #5
sdclc126 is offline sdclc126  United States
sdclc126's Avatar
Excellent for a first project - quite an undertaking to build enclosures like that.
Please tell us more about the build - what materials did you use to make the cylinders, etc?
Soft Dome
Old 7th December 2005, 11:57 PM   #6
Thanks all for the positve responses. Now, if I only had the woodworking skills of Kingdaddy (wow man)! They're constructed of 6" PVC with pine blocks for the spacers. The PVC was lined with a layer of spray asphalt (makes cats sick), and stuffed with polyfill. The caps are 3/4 MDF.
I would say that the enclosure is now more of an aperiodic membrane type in that they were tuned for a combined F3 of 50Hz, but the tubes still seemed to resonate in the midrange, thus the stuffing. I have to thank Darren Kuzma at Parts Express as I was inspired by his use of PVC on his line arrays (my next project).
Old 8th December 2005, 02:24 AM   #7
Geek is offline Geek
Geek's Avatar
Default Re: My latest concept
Sexy!
I would have those in my living room, nice work!
Old 8th December 2005, 02:32 PM   #8
kingdaddy's Avatar
Very interesting, I choose a very similar dampener called “Leak Stopper” which is a tar slurry. It works very well and deadens the enclosures very well.
Good luck and congrats on your project
Leak Stopper (great stuff if you have a few days to let it dry)
http://www.apoc.com/Gardner-5-02/ga-leakstopper.htm
Old 8th December 2005, 02:53 PM   #9
adason is offline adason  United States
adason's Avatar
one has to be carefull about diffraction with shape like that
it helps to smooth the edges and putting the speaker off center
http://www.trueaudio.com/st_diff1.htm
ed
Old 8th December 2005, 04:37 PM   #10
kneadle is offline kneadle  United States
kneadle's Avatar
Send a message via AIM to kneadle
ed
I hear this quite frequently (and read it, too ), but when I built my KatKit speakers, I couldn't hear diffraction problems, nor could I hear baffle-step loss.
Please let me make it clear that I believe the science of both, and my baffle-less projects are built knowing that they are compromise projects with respect to diffraction and baffle-step loss, but the results--the results are just phenomenal even as compromises.
Respectfully,
Dave
I have a small website for my projects.
My latest conceptHide this!Advertise here!
Help with a concept the joz Subwoofers 14 26th February 2009 07:22 AM
FS: Gain Concept No.X kirc Swap Meet 0 7th December 2007 09:40 AM
AV OB concept Geoff H Multi-Way 2 4th February 2007 06:31 PM
Another ESL Concept just.sounds Planars & Exotics 2 15th February 2006 10:35 AM
New speaker concept SY Multi-Way 3 15th September 2004 02:41 PM
