Old 4th December 2005, 06:36 AM   #1
santiu is offline santiu  United States
Default Cheap Pro Audio Crossovers and EQ for home stereo?
I was thinking about getting this:
Nady CX23SW 3-Way Stereo Crossover
to deal with my crossover duties. I'll use it as a 2-way + sub at first (BLH -> dipole woofers @ ~100Hz, subwoofer below ~40Hz).
I was also thinking about getting one of these guys:
Furman Q-2151 Dual Channel 15-Band Equalizer
to do some basic EQing.
Any thoughts or things I need to be aware of when using a products like those? Would building my own circuits yield significantly better results (I do however like the ease of adjustability of those products)? If going this sort of route, would I be better off saving up for a Behringer DCX2496 (although being an Apple user, I don't know how much I can capitalize on the computer interface)?
thanks a bunch in advance for any advice
Old 4th December 2005, 12:15 PM   #2
bogicp is offline bogicp  Yugoslavia
bogicp's Avatar
Default Re: Cheap Pro Audio Crossovers and EQ for home stereo?
Hi santiu, I'll try to help.
I never use this products, then I dont know how they works...
You can modify your transfer functions only in boundaries defined by equipement. In loudspeakers world you cannot easily expect what you will need for filtering or EQ-ing, if you need to build carefully your loudspeaker response. Only few drivers in the market has "very flat response", without needs to be equalised in some small quantities.
In general, yes, but it depends from your skills.
Good starting point is Siegfried Linkwitz site, there you will find all (active) filter topologies widely used in loudspeaker crossovers.
But, before all, you must measure frequency response of your speakers...
DCX2496 has much more possibilities than equipment you listed above, but not like your custom filters.
No problem, hope this helps.
Best regards
boggy
Dirt cheap OEM drivers and crossovers TurboFC3S Swap Meet 2 24th July 2007 09:42 PM
Cheap to good home: Audio IC's ralphs99 Swap Meet 4 20th February 2006 04:14 AM
Where can I buy active crossovers and cheap power supplies? spkerguy Parts 20 28th January 2005 02:24 AM
Cheap, simple home audio wxn Multi-Way 15 7th October 2004 05:48 PM
Making home stereo, cheap power + quality??? da_madaxeman Solid State 18 21st August 2003 12:01 PM
Page generated in 0.07897 seconds (69.09% PHP - 30.91% MySQL) with 10 queries
