Hey peeps, Just did some FR measurments using speakerworkshop on my little bookshelves/satillites..
which consist of: peerless 830881 4" nomex phase plug driver mated with a Vifa d26nc-55-06 in a 3.2L vented enclosure, tuned for about 78hz. the tweeter is offset. the front baffle is 130mm wide by 260 high Xover is at 3500Hz 12db/oct linkz , I have a 6db amp side series attentuation on the tweeter. Ive used the method as per claudio negro's guide , with the exeption of induvidual driver measurements.. i.e I did a Gated, on axis with accoustic center. Considering the drivers are so close I figured it will surfice for the moment.. I had some problems with the nearfield measurement due to the phase plug, it prevented me from getting close enough to the driver, so i compensated by moving away from the port aswell.. I think this has had an effect on low freq cutoff as it is around 80hz using a sweep.. anyway I was wondering if anyone has any ideas on the big dipper at 1 and 8k.. it appears on both my far field (non gated) and gate measurments. I tried some slightly different room positions and re marking my points for gating. but it only lessend it slightly. I also did a simple sine sweep measuremnt with audiotester and had a big dip at 9k again.. noticable around the very bumpy non gated graph.. the 1k dip was impossible to tell as a result. so does anyone have any ideas, or hints on where I should concentrate on? , could tweeter placement have such a huge impact? the tweeter certainly would have nothing to do with the 1k dip anyway so Im a bit lost. im quite happy with the rest of the results myself, it looks like I may need a db or so extra attenuation on the tweeter but from a FR pt of view i think the xover points looking ok any comments, good or bad appreciated! |
#2 |
Can you change the length of the port or stuff it and run another sweep to see if it changes position.
#3 |
are the drivers flush mounted? Regards, Claudio |
#4 |
I think we would all agree that we would need much more information then was given by mAJORD.
#5 |
sorry ppl ,
no they are not flush mounted at this time, they will be when im decided on a baffle. do you think that would make such a difference? here is a pic of my dodgy test box tog ive an idea of positioning of things. one thing that has concerned me was my need to do a 90deg port bend, something I did not want to do , but really had no choice to keep it a reasonable distance from the reard.. despite making the cabinet very deep http://www.users.on.net/~majord/peerlessmini.JPG |
#6 |
8000 hz corresponds to 2.16 cm: measure from the tweeter center this distance to see if it corresponds to something.
900 Hz =19 cm: does this value remember you something (inside cabinet dimension, for example)? Regards, Claudio |
#7 |
thanks carlos
19cm almost the depth of the cabinet (from cone to rear internal wall.. around 17cm also, almost the length of the port . 2.1cm only relates to the edge of the tweeter faceplate. the flushmounting shoudl cure this . |
| my latest diy TT project | berndt | Analogue Source | 2 | 7th August 2009 06:38 PM |
| My latest Project (nightmare) | Trout | Tubes / Valves | 14 | 26th April 2005 01:39 AM |
| Latest speaker project | DAVOhorn | Multi-Way | 7 | 21st March 2004 11:51 PM |
| pics of latest project | revisorn | Multi-Way | 3 | 5th September 2003 03:44 PM |
| Latest project for one and all | Jocko Homo | Everything Else | 10 | 30th April 2002 06:02 PM |
| Page generated in 0.09443 seconds (76.60% PHP - 23.40% MySQL) with 10 queries |
