Old 3rd December 2005, 03:37 AM   #1
Default Removable sound Insulation
I need to add simple open cell sound absorbing foam over a large area (gypsum/drywall).. The problem is that it has to stay up for 1-2 months and then be removed with mimimal damage. Do any of you have any suggestions or experience doing this? My first idea would be some double stick tape/foam tape.
Thanks in advance.
Old 3rd December 2005, 07:08 AM   #2
I'd just use small staples or nails, personally, maybe with some kind of washer arrangement to keep the foam from tearing. It might sound crazy, but it seems to me that with any adhesive tape you run the risk of causing large visible damage if it decides to take the paint off with it, or doesn't come off at all. With nails you just rub a little spackle in the hole, maybe touch up the paint and you're set.
Old 3rd December 2005, 09:33 AM   #3
Geek's Avatar
Velcro?
Old 3rd December 2005, 10:22 AM   #4
pinkmouse's Avatar
I'd just glue it onto some other drywall, and lean that against the wall, maybe with just one or two nails at the top to stop it falling.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 3rd December 2005, 03:40 PM   #5
soongsc is offline soongsc  Taiwan
soongsc's Avatar
Some fishing line across the top of the wall and clip hanging the foam like hanging negatives in a darkroom.
Hear the real thing!
sound insulation cabinet for noisy computer mali_aber Everything Else 28 12th November 2005 06:02 AM
Home depot sound insulation material for closed box woofer astarter Multi-Way 0 3rd May 2005 06:37 AM
Removable back box. How to seal? pixpop Multi-Way 7 7th February 2005 09:48 PM
rewiring an sme 3009 removable headshell sq225917 Analogue Source 0 23rd July 2004 09:34 AM
Removable TO-220 - Sockets Super_BQ Pass Labs 8 30th November 2003 09:46 PM
Page generated in 0.07387 seconds (73.04% PHP - 26.96% MySQL) with 10 queries
