Old 2nd December 2005, 04:26 PM   #1
Unhappy Floorstander
I still want to build that 2 way floorstander.
As I said before for a speaker driver I have to pay around 40-50% more
to have it!(import taxes, transport,tip, etc)
For the pair of woofers and tweeters I want to pay around 300$( including the 40-50%). But I will boost the budget a little bit more if there are major improvements!
I believe that an 8" woofer in a 40-55L enclosure would be best for the job because it reproduces HF better than a 10" one!
But if you know a good 10" that could be crossed at 1,5khz(this means low HF distorsions, good off-axis response,etc.)
Should I expect a F3 close to 30hz and a F12 lower than 20hz, without destroing the transient response?
Also I think that a 1,5Khz Xover point would be more attainable than the old 1,2khz one!
So any other new suggestions for the tweeter and the woofer?
Recently I read about some DIY ribbon tweeters! Is it possible to DIY that? Is it a wise choice?
A general question: Where is better to have the xover point in a 2 way design (closer to 1khz or closer to 3-4Khz, or somewhere else)?
By the way, what software should I use to desgin the crossover, and predict the overall performance?
Thanks!
Old 3rd December 2005, 06:03 PM   #2
Default Elliot Sound Products
Check out the following site:
http://www.sound.westhost.com/lr-passive.htm
He shows all of the math and diagrams you will ever need to design your own X-Over. Project 82 on his site is probably the coolest crossover design tool I have ever seen, but be careful about driver burnout (designing a box that allows the crossover to go too low, burning out your tweeter with too much power)
Even cooler, there is a spreadsheet that allows you to place in values for your drivers and model the thiele-small parameters of your box design.
Old 3rd December 2005, 06:07 PM   #3
Default Drivers
For driver options in a similar poject, I am considering the XT18WO09-08 and XT19TD00-04 with a crossover at 1.6K. They cost about $300 for two pair. I am working on a LR4 crossover now.
For reference, SelahaAudio uses that woofer in his SA1 design.
http://www.selahaudio.com/id46.html
It has pretty good reviews.
Old 3rd December 2005, 06:33 PM   #4
i think this might be what your looking for http://www.partsexpress.com/projects...ah8/index.html
im pretty green on home audio but this dosnt look like to bad of loud speakers.
Old 6th December 2005, 04:46 AM   #5
Thanks for the link with the "Design of Passive Crossovers".
And what about the woofer/tweeter?
Old 6th December 2005, 05:49 AM   #6
zlast is offline zlast  United States
Send a message via AIM to zlast Send a message via MSN to zlast Send a message via Yahoo to zlast
Default 2 way
http://murphyblaster.com/content.php...ifa_Tower.html
none
Old 9th December 2005, 06:41 PM   #7
Any other suggestions, are highly appreciated!
Old 9th December 2005, 07:10 PM   #8
Send a message via MSN to blank527
As an experienced speaker builder I want to show you my latest design.
It has the looks like the reference plus.. from audiocomponents... but with other units.
Units are:
Scan speak S9700.
Vifa xt18wo09-08 = Closed box
Vifa xt18wh09-08 = Bass-reflex
All measured and a constructed series-filter.
Very good sounding.
Let you know more tomorrow (if I have more time)
It's also going as a building project in a shop in Haarlem.
(see link from my ID)
Sincerely,
Remco
Old 10th December 2005, 04:04 AM   #9
kevyjo is offline kevyjo  United States
You might want to check out Seas newer CA22RNX. It looks to have a smooth enough roll off to be used in a two way but would produce very deep bass in a 50 to 70 liter cabinet because of its parameters and Xmax.
Old 10th December 2005, 04:40 PM   #10
kevyjo, CA22RNX has a very nice FR but needs a large box!
The maximum volume that I could use is 55L!
Best DIY Floorstander to Build theokalat Multi-Way 14 8th December 2009 10:41 PM
Finished floorstander pic polkymon Multi-Way 13 23rd October 2006 01:13 AM
$300 Floorstander bjackson Multi-Way 6 20th June 2005 01:50 AM
floorstander Guss Multi-Way 15 26th July 2003 02:00 PM
What floorstander to build? SRMC Multi-Way 12 13th September 2002 04:56 AM
Page generated in 0.11606 seconds (77.55% PHP - 22.45% MySQL) with 10 queries
