I've got everything else done. The case is made. The drivers mounted. Everything is wired. But the crossover is just loose inside the case. It's on a PCB board. It has what looks like screw holes but I'm not sure it's a good idea to mount it with screws. I guess it can't really short out to the the MDF case. Can I use hot glue? Bubble gum?
#2 |
Screw it to the inside wall in a convenient location. You can then easily rmove it later if required.
#3 |
Thanks.
| crossover mounting in small volume monitors | jarsoffart | Multi-Way | 0 | 7th June 2009 07:13 PM |
| reason for crossover mounting location | jaygeorge1979 | Multi-Way | 3 | 6th February 2006 01:02 PM |
| what is the mounting depth and mounting diameter of this? | lemans23 | Multi-Way | 2 | 26th October 2005 10:52 PM |
| Hi-vi B3s mounting | kenp3 | Full Range | 6 | 18th October 2005 03:33 AM |
| crossover mounting inside box? | ALFIrE | Multi-Way | 3 | 24th October 2004 06:06 PM |
| Page generated in 0.07092 seconds (67.27% PHP - 32.73% MySQL) with 10 queries |
