Blown speaker (coil?) anything I can do? Blown speaker (coil?) anything I can do? - diyAudio
Old 1st December 2005, 03:46 AM   #1
aletheian is offline aletheian  United States
aletheian's Avatar
Default Blown speaker (coil?) anything I can do?
I have an eminence speaker... it is a cheapie Legend series, that blew presumably from overheating. The rest of the speaker is good as new, so I don't have the heart to throw it out... is there anything I can do to resurrect it? Can I take it apart and re-wind the coil? The resistance reads 1.5 ohms, and the speaker was originally 8 ohms. I can hear a slight bobbin rub when I push the cone in with my hand.
I contacted Eminence about the Warranty and they gave me a real hard time, and I'll have to pay for shipping to and fro... which will cost more than the speaker itself... and that is risking that they will not honor the warrenty anyway.
Heghlu'meH QaQ jajvam!
Old 1st December 2005, 03:55 AM   #2
BAM is offline BAM
Send a message via AIM to BAM
Blown drivers are not covered under pretty much any speaker company's warranty, because it's generally considered "your fault" either through negligence or through deliberate blowing. At this point, the best you can hope for is to find a place that will re-cone the driver, or you can go buy a new one. That's just the way it is.
Old 1st December 2005, 04:11 AM   #3
aletheian's Avatar
Thaaat's what I figured. I'll probably try rewinding the thing myself... anyone have any tips?
Old 1st December 2005, 12:21 PM   #4
BAM is offline BAM
Yes, here's a tip: don't try it unless you know what your doing, which you probably don't. The results will not be good. Just wait until you can afford order a new driver, through some company like Parts Express or something.
Old 1st December 2005, 06:23 PM   #5
noodle_snacks is offline noodle_snacks  Australia
Send a message via MSN to noodle_snacks
Eminance or someone else may have an appropriate recone kit availible that would allow you to replace the entire moving assembly (voice-coil, spider, cone, surround, dust cap, gasket, lead wires) etc for some cost, it may even be possible to buy a new voice coil, it is worth investigating.
Old 1st December 2005, 06:29 PM   #6
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
When you get VC failure due to overheating it usually also causes the VC former to become distorted, so even if you can rewind it, it will probably still rub inside the gap.
If you can't get a recone kit, then you might well be able to get a whole new driver from Emminence cheaper than sending the whole cab there and back.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 1st December 2005, 06:49 PM   #7
aletheian's Avatar
Yeah, maybe I'll try that. They said none are available, but maybe if I ask real real nice ;-)
It is not a speaker that I NEED. I use it in my amp diagnostic setup, so I figured it would blow eventually... I just didn't give any thought on what to do when it did eventually go.
Old 4th December 2005, 10:54 PM   #8
CBS240 is offline CBS240  United States
CBS240's Avatar
This is a speaker I repaired a while ago with limited materials available. (obviously) A friend gave it to me because it was damaged. It was out of box sitting upright on a table and a 50lb box fell about 10ft and crushed it. There was no dust cover left and the coil was bent. I figured I had nothing to loose and disasembled it. Worst case, I had a great refrigerator magnet I was able to fix the coil... there was some metel that exteded below the coil so I just removed it and coated the coil with super glue to strengthen it after solvent use. The screwes in the base reflex tilt the whole diaphram so the coil lines up because the frame was bent as well. Pretty cheap eh? I used a piece of a paper plate for a dust cap, stapled and epoxy down. Now that's really cheap. Ironicly it sounds pretty good. Covered up, you would never know. Besides, I always thought the Fosgate series 1 sounded good anyway.
All the trouble I've ever been in started out as fun......
Blown speaker (coil?) anything I can do?Hide this!Advertise here!
Speaker sounds blown...but isn't bereanbill Tubes / Valves 16 17th June 2009 04:29 PM
question about a possibly blown speaker codyd70 Car Audio 2 19th September 2008 12:33 AM
blown speaker in a quadbox tivruski Multi-Way 0 4th November 2005 10:11 AM
blown voice coil krimet420 Multi-Way 3 10th December 2003 02:30 PM
Blown woofer- Coil replace or Passive Radiator CarMan Multi-Way 9 17th April 2003 02:40 AM
Copyright ©1999-2017 diyAudio
