Old 30th November 2005, 03:05 PM   #1
VvvvvV is offline VvvvvV  United Kingdom
Default Strange spikes and pops when doing LF sweeps
I've just installed a new Sub and moved my computer around a bit, and I thought I would test the integration with some low frequency sweeps.
There seems to be spikes in the signal coming from my computer, on the monitors it sounds like a pop like when the signal is interrupted briefly, and on the sub it sounds like someone banging on a door.
The signal from the audiofile soundcard is going through a cheap celestion sub at the moment that provides some decent in/out line level plugs. But essentially the celestion is on standby.
the frequency sweeps were fine a few months ago, but these pops only happen with very low sweeps, music is fine, what could be happening? Is it safe for my genelec ?
Old 1st December 2005, 10:39 AM   #2
Coolin is offline Coolin  Netherlands
Coolin's Avatar
It does sound like a loose connection.
It couild also be the wiring in the cable is almost broken from all the flexing. Try moving the cables while sending music over.
My DIY Pre amp switcher pops! MuthaFunk Parts 5 6th May 2009 02:07 PM
Mains pops and clicks markiemrboo Chip Amps 10 9th September 2007 09:57 AM
SPDIF clicks and pops TBM Digital Source 8 11th June 2006 09:44 PM
Amp pops on power down? jjai Instruments and Amps 2 8th March 2005 08:26 PM
Brazil, and some strange laws, not too much strange! destroyer X Everything Else 0 11th September 2004 12:38 PM
Page generated in 0.08222 seconds (68.52% PHP - 31.48% MySQL) with 10 queries
