Hi guys,
I am replacing the 17-year old electrolytic capacitors in the crossovers of my Infinity Kappa 7 speakers. These capacitors are rated at 100V. Will it be ok if I were to use 63V or 50V capacitors as their replacement? I am thinking of using Elna Silmics as replacements. 100uF Solens are too big and too expensive for me right now. Appreciate your help. Thanks. |
#2 |
What's the impedance of the speakers and what's the power level you're playing with?
It would be way better to use 100V caps. You can make a 100V cap by using 4 of the 50V caps in series-parallel.
DIYaudio for President ! |
#3 |
Thanks.
The impedence is between 4 to 6 ohms. How do you go about getting a 100V out of 50V caps? Do you connect - + + - ? |
#4 |
Let say you have a 100uf 100V cap.
With two 100uf 50V caps, - + + - will give you a 50uf 100V cap. Then you parallel that with another pair to get back at 100uf. What is the maximum power you plan to use with these speakers?
#5 |
you can use 63v 100mf capasitors.it is not problem with hi-fi amplifiers.But be careful about polarity.
#6 |
You are better off giving the eletrolytics the flick and using metallised polypopylene and even the ones cheaper than the Solens would be better than the original.
No longer DIY active |
#7 |
So an 18uf + another 18uf dosn't =36uf unless you double that again?
| paralleling film caps with electrolytic caps | jarthel | Power Supplies | 381 | 10th March 2012 08:13 AM |
| High Voltage Electrolytic Caps | Bengali | Parts | 4 | 19th October 2007 07:45 AM |
| Exceeding electrolytic cap rating | Pierre | Power Supplies | 22 | 16th September 2007 10:53 AM |
| Replacing the caps in the crossovers... | dewdrop | Multi-Way | 13 | 21st February 2006 11:56 PM |
| replacing electrolytic caps on coaxial drivers | roger2 | Car Audio | 8 | 25th March 2004 03:02 AM |
| Page generated in 0.08118 seconds (73.31% PHP - 26.69% MySQL) with 10 queries |
