Klipsch Parts help
Klipsch Parts help
Old 29th November 2005, 08:57 AM   #1
terapins is offline terapins  United States
Default Klipsch Parts help
I was wondering how I go about making a box for my klipsch parts. I have 2 6.5 woofers and a tweeter and the crossover. I would like see what I can do with this stuff, try to make something out of these pieces otherwise they are junk to me. thanks for the help, people.
Old 29th November 2005, 11:47 AM   #2
Coolin is offline Coolin  Netherlands
Coolin's Avatar
Estimate the internal size of the original box if you dont have it any more and make a new one.
Place the drivers close together for better imageing
Unless you can find specs for the drivers this is about all you can do. Unless you measure them yourself !
That takes a bit of work.
Old 29th November 2005, 06:00 PM   #3
What I have for parts are Synergy sf-3 parts. Basically I could take a speaker apart and bring it to a cabinet maker and see what the person could do..
Old 29th November 2005, 06:43 PM   #4
Coolin's Avatar
What wrong with them btw?
Just putting them in another square box wont improve the sound....
I have some other tips for you though if you want a "cleaner" more musical sound.
I have RF-3's and have done the below;
- Replace cross over resistors with non inductive ones
- Damped back wave from woofers with very dense sound absorbing material against the back wall + Rubbery something called "dynamat" in the US i beleave.
- Place small high quality caps over(paralel) the larger ones in the crossover.
Ive also improved the horns and damped the high freq. driver but thats a different story
This all really makes the sound more natural and expansive but it depends on YOUR goal and effort if its something for you.
Let me know how you like it if you make any of the changes.
Coolin
Old 29th November 2005, 07:56 PM   #5
No a friend gave me some replacement parts for current sf-3's. So the parts are just laying in a box. I just trying to make a set of speakers out of them. And I don't know how to go about that. THanks for the help!!
Old 29th November 2005, 09:09 PM   #6
Coolin's Avatar
This is the older model you probably have
http://www.klipsch.com/product/produ...id=736&s=specs
DIMENSIONS:
38.5" (97.8cm) x 9" (22.9cm) x 16.2" (41cm)
Wood will probably be 3/4 inch, its not that critical
This is the newer model
http://www.klipsch.com/product/produ...id=836&s=specs
DIMENSIONS:
42 (106.7cm) x 9.5 (24.1cm) x 16 (40.6cm)
Good luck
Old 30th November 2005, 12:25 AM   #7
PM650 is offline PM650  United States
The SF-3's are dual 8" speakers, but you said you have two 6.5" woofers, which would be for the SF-2. Is it possible that you have a mix of parts from the SF-2 and SF-3? Either way, I have a pair of SF-2's and SF-3's at home, so I can get you the dimensions of either if you like.
Old 30th November 2005, 07:22 AM   #8
Sorry about that mix up in parts. I have 8 inch not 6.5. Sorry again. Yeah get me the dimensions that would be great. Also for the horn, i think thats what it is called. What do I use for that. Can I order a part from somewhere. THanks Again......
Old 30th November 2005, 07:22 AM   #9
Could I ever make a center channel out of those products. That may be silly, but can one do that or is it just to big. thanks
Old 30th November 2005, 07:57 AM   #10
Coolin's Avatar
Yeah you can make a canter channeel why not.
If you read again i just gave you dimensions....
Klipsch Parts helpHide this!Advertise here!
KLIPSCH RF-3 35 25 and ZEN's? dshortt9 Multi-Way 14 3rd June 2013 02:07 AM
Okay, let me ask about Klipsch... ptwining Multi-Way 19 6th August 2006 05:11 AM
PARTS PARTS PARTS!!! Infocus Powerview 820, triplet, ballast, light, power supply!!! marioinla Swap Meet 1 31st August 2004 05:22 PM
WTB - Klipsch K-33's smccull Swap Meet 1 21st May 2004 04:18 AM
Value - Klipsch KG 4.5 JDeV Multi-Way 6 11th June 2003 07:05 PM
Copyright ©1999-2017 diyAudio
