FE168EZ Open Baffle
FE168EZ Open Baffle
Old 28th November 2005, 09:09 PM   #1
audioferret is offline audioferret  United States
Default FE168EZ Open Baffle
How do I calculate the low frequency dropp-off point for the FE168EZ Sigma on an open baffle? SL's Website explains the calculation in terms of finding the Fequal point, but I can't seem to make sense of his math... in Fequal .17v/D, what exactly does v and D stand for and what units should I use?
Also, in line with the Orion design, would the FE168Ez make a suitable pairup with the FT17 Supertweeter in an open baffle? I am considering the pros and cons of using different drivers in the setup. I can design and make my own electronic crossover and amplifier. I would prefer to use crossover points of 250 and 8-10K. I can't seem to find many successful examples of the 168 in an open baffle.
Last, would two FE 108s work with the FT17 in a MTM Open Baffle as an alternative?
Old 28th November 2005, 09:17 PM   #2
Drew Eckhardt is offline Drew Eckhardt  United States
Default Re: FE168EZ Open Baffle
v is the speed of sound at 1130 feet/second
D is the path difference between front and back waves
D is approximately half the width of a flat baffle but should be determined empirically
Old 29th November 2005, 01:57 AM   #3
Unhappy Is this corect>
I get 42.68 Hz when I multiply 1130 by .17 and then divide by 4.5 inches for half of the width of a 9" baffle.
Is that a correct estimation? I was estimating around 250 Hz based on the table in the "Single-Driver-Website." Does the actual driver used matter or is the primary factor the width of the baffle? If I use .75 inch plywood, do I need to take plywood material or baffle thickness into account?
Thank you for your assistance, I really like the Fostex driver and the pair I mentioned above would have a higher SAF than the current pair in the Orion. The wife is not happy about the cost either, and I need to try to minimize that...
Old 29th November 2005, 03:37 AM   #4
adolphe is offline adolphe  Canada
check your units. I think you're mixing feet and inches. That's why everyone should work in SI units
Old 29th November 2005, 03:44 AM   #5
Default Doh!
Yes, 1130 Feet/second is quite different from 13560 inches per second.
That leaves me with an FEqual coefficient of 2305.2/x where x equals half of the baffle width. Why not just keep the math simple and leave it at 2305.2/x?
I am such an idiot.
Old 29th November 2005, 07:17 AM   #6
Rudolf is offline Rudolf  Germany
Rudolf's Avatar
I wonder if you could find any! With its low Qts and small Xmax the 168E Sigma is a typical horn driver - quite the opposite of what you want for OB.
If you want to get a realistic picture of its behaviour in an OB, try xlbaffle.xls http://baseportal.de/cgi-bin/basepor...&cmd=all&Id=15
www.dipolplus.de
FE168EZ Open BaffleHide this!Advertise here!
Does open baffle suffer from baffle step? 454Casull Multi-Way 15 19th May 2012 03:12 PM
Open-baffle baffle length matejS Multi-Way 2 21st September 2010 04:49 PM
Murphy baffle radios [ open baffle ] keithpeter Full Range 10 11th September 2007 07:59 PM
what effect does baffle have on open-baffle system? kappa546 Multi-Way 6 24th January 2006 10:21 PM
Australians- what solid timbers for baffle? (open baffle loudspeaker) tktran Multi-Way 13 29th November 2004 11:09 PM
Copyright ©1999-2017 diyAudio
