#31 |
I am absolutley hopeless at building a jig .I am wondering is there anyone in Australia that would build me one if I paid for it
#32 |
make it 2.
#33 |
For those who have difficulty building the jig for SW (or other measurement software), Claudio Negro has a cable set up that should not be difficult to use or to "build". It requires no more expertise than "building" a crossover. You can see it at his home page, www.claudionegro.com, or in the Speaker Workshop Manual.
Regarding measurement software, keep in mind that there are many people out there who have built wonderful speakers from soup to nuts with Speaker Workshop. Its data is reliable for those who take the time to accurately calibrate (this is required for all software, free or not). Though there are bugs, they are few and generally identified with most of the fixes also described. The newer free software may be good, but you will find far less support and documentation available at this point. I think that the Manual and Claudio's website significantly decreases the learning curve. The 2nd Edition of the Manual will do so even more. Jay |
#34 | |
While we are on the subject of measurement software...can anyone recomend a good firewire or USB soundcard for use with a laptop. This will be primarily for measurement purposes. I'm perfectly satisfied with my current setup for doing impedance measurements on my desktop PC, but I would like to do some quasi anechoic frequency response measurements outside using my laptop. The internal soundcard just isn't linear enough for me. G.
If you take something apart and put it back together again enough times, eventually you will have two of them. |
#35 |
I get very good results with an M-Audio Transit with my laptop. It's a very small USB 2-channel device with both analog and optical inputs and outputs.
Just make sure that the s/w you're using is OK with the extra latency that a USB sound card will provide. |
| Isn't there any 3d audio simulation software out yet?? | JinMTVT | Multi-Way | 26 | 14th March 2009 02:56 AM |
| ### Searching for PC Audio Lab Software | small_boy | Everything Else | 2 | 8th March 2008 12:31 AM |
| Audio-test software | hugobors | Solid State | 7 | 11th February 2006 01:50 PM |
| New version of Audio Tester has T/S Measurement..... | venki | Multi-Way | 1 | 18th September 2005 03:09 PM |
