Any dipole experts have an opinion on this design? They certainly look impressive. Anybody heard it?
According to Linkwitz, the mid to tweeter crossover is 9kHz! http://www.jamospeakers.com/Default....roductID=17625 http://www.linkwitzlab.com/design_of_loudspeakers.htm |
#2 |
The crossover is 250 and 2000hz - look at the specifications site. But in the text it says:
"The result is a cone that can deliver output up to 9kHz without sonic break-up, a recipe for an amazingly transparent reproduction of vocals. Beyond those frequencies it’s the turn of the Scanspeak tweeter to take over." A little confusing but I think that JAMO only wants to say that the midrange driver is free from peaks and thats not typically for Seas magnesium drivers ... Im looking forward to listen to this new commerciel dipole design ! Specifications: system 3-way dipole Woofer (inch/mm) 2 x 15 / 2 x 380 Midrange (inch/mm) 5½ / 150 Tweeter (inch/mm) 1 / 25 Sensitivity (dB - 2,8V / 1m) 89 Impedance (Ohm) 4 Weight (kg/lb) 63,1 / 139.1 Dimensions (HxWxD/mm/in) 1276 x 488 x 541 / 50.2 x 19.2 x 21.3 Frequency Range 25 - 30.000 Crossover Frequency 250 and 2.000 powerShortTerm Min 800 |
#3 |
So, how easy would it be for us DIY enthusiasts to replicate these speakers?
I would assume being a commecial speak they have a passive crossover network, and therefore only passive equalization? Could a couple of high efficency, high excursion 15" woofers be passively equalized to run open baffle? |
#4 |
It sure looks like two of the new 15" SLS peerless woofers, in this configuration there would be a sensitivity of 97-100db !
To match the sensitivity of the midrange and to get rid of the dipole cancelation, you could connect a very large coil in series with the woofers, creating a first order low pass with a very low xover frequency. This would create a linear responce up to the baffel cancelation frequency, above this frequency we get a first order roll off.
#5 |
diyAudio Chief Moderator
Hmmm do you think that a point source low sens tweeter can through well at over 3 metres to follow the impact of 2x15''? At the price point it will surely find home in big living rooms. Waiting for first impressions.
#6 |
I'm not sure that I follow what you are saying. If the xover is at 250Hz, you are looking at using 12dB of the woofers sensitivity to reach at least 75 Hz !
| Jamo Dynamic 80 | c0nfu33io | Multi-Way | 2 | 31st July 2009 03:05 PM |
| Fostex FE126E reference design opinions | baggystevo82 | Full Range | 14 | 16th July 2005 11:38 AM |
| scan-speak reference-plus opinions | dan _s | Multi-Way | 28 | 15th March 2005 07:49 AM |
| Any website reference for diy Audio Research REFERENCE amp and Manley Studio amp | bmpa | Tubes / Valves | 4 | 19th April 2004 05:11 AM |
| Opinions on Jamo | sangram | Multi-Way | 15 | 30th April 2003 02:52 PM |
| Page generated in 0.09431 seconds (74.56% PHP - 25.44% MySQL) with 11 queries |
