I am starting my first DIY project, so I am very new to this. I bought a pair of Aurum Cantus 130MKII 5.25" drivers for a small 2-way. They are listed as having a Fs = 38 and Vas = 27L. With speaker workshop I measure them at Fs = 50 and Vas = 15.5L. I have read that actual measurements can stray from published, but this seems like a bit much to me. I measured both drivers and they match each other within 1% for Fs, Vas and Qts. Should I be coincerned about the accuracy of my measuremets, or should I procede with enclosure design with the measured results?
Thanks, Chad |
#2 |
just another
Hi Chad,
1st have you broken in the drivers?? the fs will probably drop at least 10% (which would be around 45Hz) after breakin, and that would be well within the expected range I'd say.... Certainly with the higher FS the VAS should be lower, so your overall ratios are probably ok, and shouldn't affect the enclosure design per se. The other thing is what level did you do your impedance measurements at?? I always do mine at a very low level, (around 4K on the VU meter), T/S params will vary depending on the level you drive the woofer at, Vance Dickason recommends using the lowest level that your measuring equipment can use. whether you can get clean results at that low a level will depend on your sound card though. Tony. |
#3 |
That makes perfect sense. I hadn't thought at all about break-in. Do you have a recomended break-in procedure? My VU meter is about 4500 for the left and 4000 for the right (i guess thats because of the resistor
PS. I am using a seperate integrated amp for these tests, not an output direct from the card. Thanks for your help, Chad |
#4 |
just another
Probably best to do a search on breakin, lots of different oppinions and methods... My method didn't appear to be very successful
4k was the peak VU value, though if you are using a separate amp, with attenuating resistors then 4k could well be too high....does the pssssshhhhhhh coming from the speakers when doing the impedance measurement sound pretty quiet?? if it is loud then the level is probably too high (this will of course depend to a degree on the speakers sensitivity) I have an Audigy II ZS which is quite capable of driving the speakers direct for the impedance measurement I don't use the separate amp for this test. I don't think it should be necessary to recalibrate for different levels, as the resistors you use for calibrating shouldn't be affected by voltage level too much, voice coils in loudspeakers are a different animal though and are effected by drive level, but it certainly can't hurt to redo the calibration Yes you should keep the recording level constant and reduce the power going to the speaker... there will probably be an optimum record level for your particular sound card, where you get the optimal results, experimenting with RMAA is a good way to find the optimal settings for your card. I know on mine increasing the recording level increases noise and distortion a lot! Tony. |
#5 | |
your measured results indicate a stiffer than specified suspension, and the measured Qts should also be higher than specified. If the box you are planning is less than around 10 litres the lower measured Vas of the drivers will barely affect the alignment, in fact if you are planning a small bass reflex the stiffer suspension is actually an advantage when dealing with sub-sonic bass. |
| measuring speaker impedance | dallaire | Multi-Way | 4 | 11th December 2007 10:44 AM |
| Measuring CCS impedance and at different frequencys | Kevinbd | Solid State | 1 | 22nd October 2004 07:00 AM |
| Measuring speaker impedance | gary f | Multi-Way | 12 | 5th June 2004 12:18 AM |
| measuring Input impedance of an Amplifier | pinkmouse | Solid State | 5 | 23rd May 2002 08:15 PM |
| Measuring PSU supply line impedance? | Kevinbd | Solid State | 3 | 20th May 2002 08:56 AM |
| Page generated in 0.09142 seconds (78.25% PHP - 21.75% MySQL) with 10 queries |
