Hi
I'm presently using my Behringer DCX to split the signal between my dipole sub and my dipole fullrange. The fullrange dipole does not have to go trough the Behringer, cause I do not manipulate the signal in any way. So it's only for LP to the sub realy. I do have a autodelay in the beringer, to compensate the runtime tweeter/midrange to bass. I run only small amount of EQ in the bass, and would sacrifice the eq just for a test. To try a simpler system, I would like to tap the fullrange signal from the main speaker, and LP it to the sub amplifier. I have got hold of a 12dB RCRC schematics which I'd like to try. Is there any other suggestions on solving this? Any experience on wheter I should just stick to the Behringer, or try something else? I could also tap the linelevel signal and feed the Behringer and just do the bass trough the DCX. But the signal would be quite low. Suggestions? best regards Bjorn |
| Level control on op amp crossover | mashaffer | Solid State | 5 | 10th August 2008 12:19 AM |
| Speaker level to line level converters | qguy | Subwoofers | 2 | 9th December 2007 03:58 PM |
| speaker level input vs line level question | crippledchicken | Subwoofers | 4 | 17th July 2007 03:36 AM |
| $30 Active Line-Level Crossover | Nappylady | Multi-Way | 23 | 20th September 2005 06:53 PM |
| Passive line level crossover | rulezzz | Multi-Way | 3 | 7th January 2004 08:45 AM |
| Page generated in 0.07607 seconds (71.20% PHP - 28.80% MySQL) with 10 queries |
