Hello
I have been searching and simulating for a while on active filters, especailly those Linkwitz-riley and bessel, I was surfing in www.linkwitzlab.com and www.sound.au.com. I think its time to crystallize my thoughts now.. Any way, I have two 12" loudspeakers which are best dedicated for midrange audio spectrum, and two 4 Ohm tweeters, those types which have a coil, means no peizo, cuz I don't like the way it sounds. I will buy th subwoofer later on, while discussing this system on the forum.. If I want to build 4th order LR HP filters based on Rod's formulas, and use a cut-off frequency of 250Hz, or 310Hz. And build a 4th order LR LP filter which sums the L & R channels, and has variable gain circuit based on an opamp like that described in linkwitzlab, also will have a cut-off frequency which is the same as that of LR HP filter. I am aware of the fact that I will have to use Linkwitz transform circuit if I use a closed box for the sub, and may be the sub controller in Rod's pages, so I will not use the 4th order LR LP filter with the later configuration. Now, the sub will have its own enclosure, but I still don't know which to use, clsed or veted box, and the two 12" speaker + tweeters will be fitted in separate closed enclusures, each closed enclusure will contain a 12"speaker and a tweeter. I was wondering if I use a 2nd order passive LR HP filter for the tweeters at 4Khz or 6Khz, because I am still afraid that tweeters may be at risk when I have the cutoff frequency of the LR HP active filters at 250Hz or 310Hz . Would that bring problems to my new Bi-amped system if I use passive filters with the LR active crossovers. I already have 10s of amplifiers ready to pump, ranging from 20 watt to 200 watt, but I only want to apply Bi-amping to my new audio system, although I could use three-way active filters, but this will increase the wiring work, don't care about the cost though, I don't know, may be there is somebody who can bring a better idea justifying that a Tri-amped system is much better, and has more details in the sound. Also I need a calculator software to make the 2nd order LR passive filter. Another thing, I saw that Linkwitz uses delays in his crossover circuits, especially at the HP LR filters, shall I worry about that too, in case I go to Tri-amped system, and shall I worry about it if I am still going for Bi-amped system . Also can you guys suggest something practical about power distribution in both Bi-amped, and Tri-amped systems. I am still doubted about the sut-off frequency in deed, though I feel its ok, but deeply, I don't feel its ok. Thanks in advance |
#2 |
Hi
Have you considered buying a digital xo like the DCX2496 ?, then you can try out various orders, gain, delay and xo frequencies. after trying out the best configration you can build a "supercircuit". and if you dont want the DCX after that you can allways sell it (cheap)to me. I want one more DVC Keld |
#3 |
Hi
Simply NO, cuz I don't know where to get that digi thingy from, if you want more filters, I can sell them to you readily assembled on vero boards, but without opamps I still have the option to experiment using a breadboaord... Any way, I have tinned and green masked vero boards which are more useful and trustable than the ordinary non-tinned. They cost me 2.75$ each I think I like this one , as it seems alot impressive to me in deed, but won't build them as I don't know how to make it two-way, also linkwitz seems to have optimized this three-way crossover for a specific speaker system. I will post my schematics later |
#4 |
Hi
Where are the audio monsters ?? |
#5 | |||
which should not affect the operation of the active crossover. Quote:
Though reality is a little more complicated ........ Its highly unlikely a standard LR c/o will suit your drivers. Quote:
driver amplitude response, phase response, and mounting effects. The power distribution depends somewhat on the relative efficiencies of the sections you are driving, but for c/o points of 300 and 3kHz i'd say ~50% bass, ~30% midrange, ~20% treble. |
#6 | ||||
#7 | |
hard to say which is better - depends on circumstances. Regarding c/o design - say your target is 4th order L/R acoustic response for the mid/treble crossover. This cannot be implemented by an off the shelf c/o, to achieve this design goal the c/o must be exactly matched to the drivers when they are mounted in the final enclosure - not easy. |
#8 |
Did it Himself
I'd also add that a summed sub channel going as high as 300Hz is going to not be good for the stereo image. You want a summed channel to be 100Hz or lower really. If you must cross that high then use stereo subs.
I also question why you are trying to use 12 inch speakers as mids, but also crossing them far too high for high fidelity. Are you building a PA system?
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#9 | |
Hello All
In deed, I was amazed this morning, I used STK4191V @-/+ 36 Volts, and wanted to test the two 12" speakers to see where to choose the cut-off frequency. I used TrueRTA, I started from the lower end @ 20Hz, and put a 1K resistor in series with one of the speakers, and started measuring the voltage drop across that resistor to see where I get the highest voltage drop at the first lowest frequecy while sweeping, I got that at 565Hz, but I still can find that there are dips and peaks in the speaker response at many different frequencies, any way, that will not work. Thanks to David B. Weems book "Great Sound Stero Speakers", I saw that he explained how to measure Fs, Qtc, and Vas of a speaker, I will apply these tests to the two 12" speakers, and start designing a closed box for them, may be not !! I also read in another book that its best to have two bass woofers, and be able to sum their inputs to have a mono bass output which means you can have stereo or mono bass output, thats because if you are watching a movie, then you switch to mono, saying that the results are much more thundering rather than a stereo when listening to horses or gun shots, while for music, you beter switch it to stereo. And as richie said, that filter was far below 100Hz, it was tuned at 70Hz, thats correct richie, thank you Any way, returning to the 12" speakers, I removed the 1K resistor, and started listening, what the hell I was trying to do man, it seems If I use these speakers, I will end up with a PA system, the sound was too loud, and I had to close my ears, becasue I could not stand both the High-end bass, neither the mids In deed I am almost lost now, I think I will have to go for 8/10" speakers, put them in a closed box, and use 12" subwoofer @ cut-off frequency @ 100Hz as richie said, as I don't need a PA system in my room, so at last, I will be kicked out, as was gonna happen today, when police came asking who is the hell was playing too loud, neighbours were just sick of it Also I will use STK4191V for the sub, bring two other STk4161V/4141V for the speakers and tweeters respectivelty. I don't know, may be you guys have some thing else to say Quote:
#10 |
I agree with the other poster. That gap between the tweeter and 10inch mid needs to be filled in with a more appropriate mid. Maybe in the range 4inch to 6inch. This then makes it a 4 way system, allowing you to dedicate the sub to real sub duty say up to about 120Hz. Can I suggest you build the system as active initially using a DCX2496 to select all the parameters, then sell it on and use the data to generate the active or passive crossovers. If you go the passive route then also consider using an amplifier dedicated to each driver and its crossover section. (bi-amping or tri-amping in the UK)
regards Andrew T. |
| SQ System - Need your suggestions | omar_uh | Car Audio | 2 | 31st March 2009 09:44 PM |
| Tri-Amped suggestions | argofanatic | Multi-Way | 4 | 26th October 2005 07:29 PM |
| active filter from rod elliot and sub filter questions | wuffer | Parts | 0 | 2nd October 2005 01:12 PM |
| tri-amped system .. computer as xo? | kfr01 | Digital Source | 2 | 14th October 2004 01:54 PM |
| Where to place the amps in bi-amped/tri-amped | Xicarius | Everything Else | 1 | 4th August 2004 12:13 PM |
| Page generated in 0.15918 seconds (86.02% PHP - 13.98% MySQL) with 10 queries |
