My Morel MTM Project
Old 10th November 2011, 11:22 AM   #141
pheonix358 is offline pheonix358  Australia
pheonix358's Avatar
Nicely done!
What we don't understand is called magic.
Old 10th November 2011, 11:27 AM   #142
AllenB is offline AllenB  Australia
Originally Posted by wintermute View Post
I think there is something suspect with the phase,
It looks like group delay, maybe 1 to 2cm in the measuring distance.
On Love Over Gold I can't go past Telegraph Road, myself.
Old 10th November 2011, 11:37 AM   #143
wintermute is offline wintermute  Australia
just another
wintermute's Avatar
Thanks Terry!
Allen yes it would only be about a cm I would guess, I should have marked where the feet were, to get an exact match but wasn't thinking
edit: I love telegraph road as well, but I just can't go past the strings and drums in private investigations. Piano is great too.
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Last edited by wintermute; 10th November 2011 at 11:40 AM. Reason: add telegraph road comment
Old 11th September 2013, 09:16 AM   #144
tcpip is offline tcpip  India
Hey, what's the current picture? Are you still planning to add the woofer at 300Hz?
Old 11th September 2013, 12:38 PM   #145
just another
wintermute's Avatar
Hi tcpip, yes, but it may be 200Hz. I have to get my active crossover project back on the boil. I took some in room measurements of the MTM's and the 10" current cabinets last week with the idea that I would tailer the active crossover to give me the best response in room. I've put the circuit diagram into tinycad and need to do the board layout (verro board). I might need to revise to third order electrical on the bass though I suspect (only addition of one resistor to my circuit though I think).
It's a very slow process with me unfortunately
Tony.
Some of my photos
Old 11th September 2013, 01:02 PM   #146
I have some thoughts on my own 3-way project which may have some bearing on this. Hope you get around to reading this page which has all my thoughts and rationale.
I have been thinking of this 3-way for a long time. There is this strange belief among many speaker builders that the human voice is between 300-3000Hz. The reality is that male voices can go much lower than 300Hz, maybe down to 150. And the 300-3000Hz range is the range of maximum sensitivity of our ears, but not the range of the human voices. Since we all want to get fantastic realism with the human voices, I don't want to entrust a woofer with the job. The driver which reproduces the thump-thump of bass percussion with large Xmax should not be asked to reproduce any part of the human voice range, I felt.
Therefore, I was thinking of crossing over my woofer at 100Hz. This is also the reason why I want a conventional midbass driver (at least 6", with an Fs below 80Hz) for my midrange. I can't use a typical ultra-low-Xmax ultra-sensitive 4" midrange driver.
There is another reason (very attractive to a lazy designer like me) to do this. If you push down the Fc lower and lower, it becomes less and less critical getting phase alignment between woofer and midrange at Fc. Think about it. At 100Hz, the wavelength is about about 11-12 feet. This means that woofer and midrange will need to be displaced by 3 feet to be out of phase by even 90-degrees. This gives the designer a much larger margin for error than, say, at 200Hz or 300Hz.
Therefore, for my 3-way, I was thinking of simply building an electrical LR4 LP for the woofer at 100Hz (which would also pretty much give me acoustic LR4), and an acoustic LR4 for the midrange in its sealed enclosure. I could do this by using LT to get 2nd order at 100Hz, and then adding another electrical LR2 to make it fourth order. I have a suspicion that textbook filters will do the job, and no careful phase matching will be needed.
These were the two reasons why I suggest that you consider moving your Fc down. You'll get the active filters built on breadboard in no time, and no measurements (other than impedance measurement of the midrange in its enclosure for the LT) will be needed.
Does this make sense?
Old 11th September 2013, 06:34 PM   #147
Would you need the Linkwitz transform if you built the box for the 100Hz response?
Old 11th September 2013, 07:20 PM   #148
I guess you are referring to the midrange box, right?
In that case, if you have accurate T/S parameters of the driver and can size your enclosure to get 0.7 Qts in the box, then you can skip the LT. I was intending to size and shape the box as per my convenience, and then use LT to get the rolloff to fit. Gives me more flexibility in box dimensions.
Old 12th September 2013, 04:45 AM   #149
pheonix358's Avatar
snip
Please consider the following.
Most 6" drivers will happily go down to 120Hz in a sealed box. You get a better midbass performance.
I would never cross to a sub any lower than 150Hz and any sub should handle this easily. There is no stereo info at or below 150 Hz, ther can be at higher Fs.
Just my two cents worth.
P
Old 12th September 2013, 07:58 AM   #150
We are not talking about a sub here. We are talking about a woofer in a 3-way design. The fact of whether there is or isn't any stereo separation is not very relevant here, right, once we have already decided to put one woofer driver per channel?
Therefore can you please explain your thoughts a bit here? Why not cross over below 150Hz?
My Morel MTM ProjectHide this!Advertise here!
Dusted off an old project. Morel Pure_Brew Multi-Way 7 3rd June 2010 04:14 PM
My MTM Project Twisted85 Multi-Way 34 10th March 2008 04:10 PM
Morel 3-way tri-amped project Joe-Al Multi-Way 0 12th December 2005 05:20 PM
new morel MTM project: rantings wintermute Multi-Way 22 30th January 2005 12:13 PM
Help with Morel sub project andrew Multi-Way 5 11th May 2002 03:29 AM
Copyright ©1999-2017 diyAudio
