Lowther Fidelio - anybody? - Page 2 - diyAudio
Old 9th January 2003, 10:19 PM   #11
diyAudio Senior Member
fdegrove's Avatar
Default FIDELIO
There must be other people here using Lowthers surely.
The Fidelio never really struck me as a good design,I've heard cabinets for various Lowthers that were much better balanced.
My advise would be to get in touch with the various Lowther Clubs all over the world (most countries have at least one) and listen to what they have to say.
Hans, how long have you used your OTL with Lowthers? I was always afraid to put out an OTL for Lowthers because of the systematic attention these amps require to maintain minimum DC. Is your amp capacitor coupled to the Lowther?
An OTL on a Lowther?
Seems like burning power to me...I'm curious about this set up.
Frank
Old 10th January 2003, 11:11 AM   #12
Hi
I have used my OTL now for about 3 years without any adjustment necessary at all. I usually check bias and DC on the output every 3 months, (I used to do it more often but as it doesn't change I decided it was not needed). I know why adjustment is often necessary in many commercial OTL amps but I never understood why users accept something like that.
Horn loaded Lowthers is an ideal load for an OTL amp as the efficiency of the lowther means that the OTL have a very easy life, also the impedance curve on the lowther is much nicer then many multi element speakers. My Lowther elements is 8 ohm version.
I have listen to many different Lowther equipped speakers, (one of many good things of living in Tokyo is that there is wast offering of high-end equipment) and for me I think the Fidelio is a good compromise, the sound is quite dry and true as it is less colored than in many of the larger horns.
Regards Hans
Old 14th March 2007, 09:01 PM   #13
Hi Big Swede, I've been using some Fidelios for the last 8 years with DX3 drivers to start with which have been upgraded to EX3 drivers 3 years ago. The cabinets were built out of birch multi-ply. I find the Fidelios communicate small-scale musical performance particularly well, delivering an intimate and quite tangible sound stage. If you're looking for large-scale, deep bass type music, go elsewhere! I use the Fidelios with a 9W 300B SET amplifier and vinyl front end. Hope this is of help to you!
Old 9th April 2007, 11:26 PM   #14
Yes, Fidelios are a good compromise. My personal favourite is the ALFREDO Horn designed by one of my friends ALF LEPP. It is a backwave loaded Tractirix horn about the same height and width as the Fidelio but about 70cm deep. Mouth opens to the front. I prefer this to the Fidelio and Academy. It is less coloured than the Mau Horn Type IV. Sound stage is larger than the Fidelio and Academy but smaller than the TP-!. I have tried 6A, 6C, 7A, 7C, DX3, 2A, 2C and 5A in this cabinet. Optimum driver is the PM7C, white paper cone.
This is and has been the norm at our Club Meetings over the past 8+ years.
Mohan
Old 30th July 2007, 09:23 PM   #15
Default Fidelios with 15 Ohm DX2
I use my pair for a couple of years now and I do not think I will change to something else w/o a VERY good reason.
My amps are due to be replaced (solid state, not the best match), then the preamp, and then somewhere in the future I may consider another horns (smth. like Heldlund, probably down- or backfiring) and/or alnico Lowther drivers, but I will not willingly part from my Fidelios.
Old 5th January 2008, 04:52 PM   #16
Default Alfredo Horn
Hi Mohan, I have couple of PM7C's that are left over from another project years ago, I would love to make exactly what you have and showcase it in my lounge back in London, England :-)
Please could you tell me the best way to go about such a task, does Alf Lepp have a website, or can you help me ??
many thanks - Peter
Mohan
Old 6th February 2008, 05:55 PM   #17
hifido is offline hifido  Canada
Default alfredo horn
Hi.
Does anyone know were I can find a drawing (plan) for the Alfredo horn speaker
Thanks.
Old 7th February 2008, 10:13 AM   #18
marec is offline marec  United Kingdom
I guess this is a little late now, but I've had a pair of the Fidelio's big sisters (Delphics) for about 15 years.
They sound ok, but need a largish room and some care in positioning to get the best out of them.
Given the complexity of cabinet construction and the room requirements, I would recommend one of MJK's open baffle projects as a more satisfactory alternative. The combo of PM2 + 2*15" Eminences works outstandingly well IMHO. For a more acceptably sized option, Martin's new Fostex OB is currently giving me lots of pleasure...
Old 8th October 2015, 04:37 PM   #19
bubasan is offline bubasan  Croatia
Default Lowther speakers EX 3 in Fidelio horn boxes
Hello
I have finished Fidelio boxes EX3 drivers with thirty hours of use, ie in the labor
condition (as recommended by the Lowther).
The sound is full of fine detail and perfect for tube amps. My performance by strictly
followed Lowther designs with 8 Ohm drivers so that the classic amplifiers
come to the fore.
Drago,
bubasan6969@gmail.com
Advice on SE DHT for Lowther Fidelio DX2 Rudolfs1972 Tubes / Valves 5 31st July 2007 10:18 PM
Lowther GB. steenoe Group Buys 35 3rd February 2006 02:47 PM
Lowther GB. steenoe Pass Labs 15 20th January 2006 06:20 PM
Lowther GB? steenoe Full Range 10 15th January 2006 07:54 PM
Fidelio cabinets with FOSTEX FE 208 Sigma Jaskier Full Range 4 16th October 2003 06:29 AM
Copyright 1999-2017 diyAudio
