Old 20th November 2005, 03:01 AM   #11
Send a message via AIM to ocool_15 Send a message via Yahoo to ocool_15
I was thinking of just using fiberglass resin. I have one or 2 where the T-nuts came out(removing some mdf) so was going to replace them. Haven't tried but perhaps the mdf absorbs resine too much....
Old 20th November 2005, 08:50 AM   #12
Originally posted by DSP_Geek
That makes a lot of sense. Araldite is a right pain to find on this side of the pond, so I'll look at other things. I wonder if Gorilla Glue would work.
I'd be worried that Gorilla Glue would foam up everywhere and get into the threads TBH.
Maybe if you covered the bolt in grease and applied the GG to the nuts with the bolt in place, it would stop the threads getting GG in them and allow you to easily remove the bolt?
I reckon epoxy glue would be better than GG though.
Old 20th November 2005, 06:52 PM   #13
Does anyone have problems with air leaks through the threads?
Just to be sure, on the sub I'm building I epoxied in 1 1/2" long hardwood dowels and threaded them 10-24 (5 mm for you metric guys) for machine screws.
Noah
Old 20th November 2005, 07:08 PM   #14
Did it Himself
richie00boy's Avatar
I glued them in with 'No More Nails' which I believe is a polyurathene based glue similar to Gorilla Glue. Just a splodge under when they are halfway in.
Although I've never had a problem with a tee nut falling out even when not glued.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Gluing and Clamping wintermute Construction Tips 6 25th August 2009 03:09 AM
Gluing questions rbmcginnis Planars & Exotics 11 31st July 2006 05:06 PM
Wet gluing veneer tiroth Multi-Way 11 22nd October 2004 07:12 PM
re-gluing a separated surround speekergeek Multi-Way 1 29th October 2003 01:21 AM
Page generated in 0.09299 seconds (76.79% PHP - 23.21% MySQL) with 10 queries
