I am looking to build a PA system for parties etc, I would like to build something fairly robust with high efficiency (95db+, 100db ideal) any projects worth looking at or driver suggestions? Budget is about 800AU max.
#2 |
Speakerholic
How big?
One 15" woofer and a horn tweeter? Or do you need more than that? |
#3 |
Are you looking for efficiency or volume? I believe that there's someone on the forum who built a PA that sounded pretty darn nice out of NSB's, might be worth considering.
#4 |
I did a sub sat system with a 15 sub and two 10s and horns.
I needed the coverage of speakers in the air but the nice bottom you get from putting a sub on the floor. it turened out sounding ok with 2 pro amps one in bridge running the sub and the other one powering passivly crossed tops. Had I done it today i would probably run 12inch drivers rather then the 10s for the tops.It just sounds a bit thin when you are close to the sats and at a distance from the sub. Or heck why not two 10s and a 1 inch driver. i would recomend against a 15 inch and a 1 inch because of the problem you will get in the upper midrange.Maybe a 15 and a 2 inch crossed low but then youll loose out on the really high frqs.
thanks for reading. H.Honda Chico CA Land of the fooled |
#5 |
You could check out adire audio's HE 10.1, I have not heard it but the reviews of it have been good and it meets your requirements.
http://www.adireaudio.com/Home/KITHE10-1.htm |
#6 |
Id go for Paudio bits as their easily available. You can always order through shanghaiproaudio if you dont like the cannonsound prices.
Perhaps http://www.speakerplans.com/index.php?id=x12 |
| Power supply:Universal AC input/ Full range,High Efficiency, and High reliability | hang | Vendor's Bazaar | 12 | 24th July 2009 03:46 AM |
| How are these bass units for a high efficiency system? Eminence EMI-1550/Fostex FW405 | sqlkev | Multi-Way | 10 | 15th January 2008 08:16 AM |
| Suggestions for High Efficiency system - BetaCX? | mpmarino | Multi-Way | 34 | 23rd July 2005 05:17 PM |
| FS: High-efficiency DIY-kit Speaker System, circa 1960... | GordonW | Swap Meet | 1 | 12th March 2005 05:40 AM |
| Suggestions for high efficiency high SPL kit/design | Kanga | Multi-Way | 50 | 23rd May 2003 12:52 AM |
| Page generated in 0.12565 seconds (54.11% PHP - 45.89% MySQL) with 10 queries |
