Hello everybody!
Let's assume that we have single-port bass-reflex enclosure with known Vas, Fb, Sport, Lport (therefore we can calculate port quality Qp). Then we substitute initial port with N equal smaller ports with the same length Lp and with Sport/N area (each). Fb of such an enclosure will stay the same, of course (let's not consider edge effects now). The question is: What will be "new" Q'p? N*Qp? (N^2)*Qp? Something more complex? Thanks in advance! |
#2 |
Did it Himself
I would imagine that the new Qp would be very slightly higher than original, and the 'scale factor' depends on how many smaller ports you use.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#3 |
Port Q depends on more than just area, it is also drive level dependant.
Best Port Q should be with a single port vs multiple ports of the same area/length because a single port has the smallest surface/ volume ratio. What is the goal of this exercise, the point to the question?
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
#4 | |
knowing that a small tube has more resistance to air flow than a big tube then extrapolating to a number of small tubes of equal area to a big tube. I would expect that the air resistance for equal area would be higher for a group of small tubes. This would imply that Qp would be lower. This fits Ron's comment;- Quote:
Sorry, keep asking.
regards Andrew T. |
| bass-reflex with 2 different ports? | andrew24 | Subwoofers | 6 | 4th July 2009 02:54 AM |
| [Theory] Best impulse response in Bass Reflex enclosures | Jose Hidalgo | Subwoofers | 23 | 26th June 2007 07:38 AM |
| Two ports in a 2-way bass-reflex speaker | alvinlim | Multi-Way | 3 | 15th February 2006 10:41 AM |
| Nice looking reflex ports | mark.carline | Multi-Way | 2 | 10th May 2004 06:39 PM |
| curved ports vs. multiple ports | Craig | Multi-Way | 1 | 22nd September 2002 07:30 AM |
| Page generated in 0.07863 seconds (68.86% PHP - 31.14% MySQL) with 10 queries |
