Old 18th November 2005, 01:12 PM   #1
rick57 is offline rick57
Default Best horn 50 450: U horn?
Im looking around for the best kind of horn for about 50 450 Hz.
I have very low Qes JBL drivers suited to cover that range (fs 50 Hz, Fhm of 590 Hz).
Straight horns are simplest, and I could live with their length (if downward firing into a concrete floor); but integration is harder with a mouth near floor level, esp. crossing at 450 Hz.
I just came across the U horn:
http://hem.passagen.se/sajberrapid/50hz.html a 50 Hz Hyperbolic Exponential horn, from Mattias in Sweden.
I might try to contact him to see how he input some parameters into Hornresp, but first ~
I havent seen anything like it does anyone have a suggestion for a better way of covering that range in a horn/ see any disadvantages?
Or read about any other U horns??
Old 18th November 2005, 02:08 PM   #2
DorinD is offline DorinD  Romania
DorinD's Avatar
Why not choose Edgard's "Show-Horn"?
A copy of the B.Edgar article here:
http://www.volvotreter.de ->Downloads
My clone re-calculated for 70Hz here:
http://www.hi-fi.ro/fhifi/viewtopic.php?t=5278&start=0
Dorin
Old 19th November 2005, 12:35 AM   #3
Default Folding geometry - U horns
Hi
(I cant read Romanian, but thanks). The Show Horn etc ~
Im trying to really optimise the upper range of a bass horn (my JBL drivers Fhm is 590 Hz), up to at least 500 Hz. The Show Horn was a new benchmark in 1988, but Im trying to see if some refinements have been done since then ~
Eg the Show Horn article has the theory, but I wonder if the 90 degree turns in the SH might reduce transient response above 300 Hz, compared with curved turns like in a U horn?
Edgar acknowledged that he had to compromise the SH with a quasi 180 degree bend, presumably because he wanted it to be portable. Apparently the University Classic doesnt have that compromise, but if IIRC it was lot bigger.
http://hem.passagen.se/sajberrapid/50hz.html.
Any thoughts on this, curved turns or any other U horns?
Any disadvantages (other than trickier building) in curved turns?
Old 19th November 2005, 08:15 AM   #4
BTW Dorin,
just looked at the pictures - the cabinets look superb!
Cheers
Old 19th November 2005, 12:23 PM   #5
DorinD's Avatar
Originally posted by rick57
BTW Dorin,
Cheers
Thanks!
To optimise the upper response of the basshorn you have to pay attention to the front chamber formed by driver's cone and throath of the horn and maybe use a phaseplug. Your intended driver (590Hz for 2*Fs/Qe) is excellent and worth the effort to try any method to get usable output up to 500Hz (maybe 600).
Horn experts - Please help to determine optimal throat size for low-mid horn pk Multi-Way 9 19th August 2012 07:29 PM
Single Driver Horn Base Port from Frugal Horn EmergencyDpt Swap Meet 0 26th October 2008 02:24 AM
RCA MI-1425 with MI-1469 Horn, MI-1457 (W-horn) with RCA MI-? fieldcoil woofer thekop-bkk Swap Meet 0 26th September 2008 04:55 AM
looking for 6.5inch woofers suitable for a 30 - 35Hz horn... and a small horn too :P SkinnyBoy Multi-Way 24 13th February 2004 06:06 AM
Copyright ©1999-2017 diyAudio
